ss/sc ss/tc swap
ss/sc ss/tc swap
i kno i just made a list of mods for my sc cobalt. but is there anyway you would be able to swap the ss/sc engine with the new ss/tc engine? i kno its the Pontiac Solstice GXP engine but if it fits in the new cobalt i assume it'd fit in mine. plus it beats spending around 3 grand and still not making it into the 12s. if its possible where might i be able to find this engine?
Wait are you trying to swap the LNF into the SS/SC, or the LSJ into the SS/TC?
Very much so..and you'll get tons more power.
Last edited by Scythe_Snake; Feb 28, 2008 at 01:37 PM. Reason: Automerged Doublepost
if i could find one. plus wouldnt i have trouble with inspection
i wanted to mod my supercharger but no matter what i do it'll cost too much to be even remotly fast. so i wanted to make it turbo. i figured buying the solstice engine woudl be cheaper then custom maken my own.
Last edited by srcobaltss; Feb 28, 2008 at 01:39 PM. Reason: Automerged Doublepost
If you want to get a turbo, buy Rebel auto worxs or tag's turbo kit. It will be significantly cheaper.
LNF = between 2.5-3K
Install = At least a 1K MINIMUM.
And you did all that to have a stock engine in which you could have modded your LSJ significantly with.
FALSE. Swapping a new engine, one that is generally maxed out and not at all mod friendly will not lend you higher numbers. A turbo LSJ will out perform a LNF. The LNF is seriously limited thanks to the direct injection and ecu i believe. And the f35 tranny is maxed out on this engine.
And if you had full bolt ons, stage 2 w/ upgraded pully, port-polish head and sc you'd be closer to the 12s.
Secondly....like I said, either get the new TVS, or a turbo. A turbo LSJ WILL out perform an LSJ and be cheaper. You'll be seeing closer to the 12s with the turbo swap.
And its no different with most cars. To get them to run a full 2 seconds faster IS NOT going to happen with full bolt ons. Maybe cars like the MS3 and SRT-4, but they are both pwnage vehicles.
But, think of the si..full bolt ons for most doesn't even get them out of the 14s, for some good drivers yes, but most it doesn't. they usually have to FI swaps to do that.
I think you may be disappointed one you get your LNF though....
Russo lets not get our excitement too overdone. Lets wait and see when it comes out, then make our judgements. But like you, I am very excited for the TVS.
https://www.cobaltss.net/forums/advanced-performance-modifications-130/harrop-htv1320-lsj-using-eaton-tvs-technology-91586/
Last edited by Scythe_Snake; Feb 28, 2008 at 02:02 PM. Reason: Automerged Doublepost
Hell I under estimated the crate engine. but yes, it usually comes without the intake piping and the turbo-exhaust manifold as well. So if you just want a turbo cobalt so bad, just go out and buy one. These aren't Honda's, you can't just drop and go. Or turbo your LSJ.
$2250 shipped. Go to the 10+ page thread all about it, and read.
https://www.cobaltss.net/forums/showthread.php?t=91586
True I need to keep calm tho.
lol WHERE the hell is that? Sorry I'm not sure... North, South? Mid?
south jersey. 45 minutes from philly
Last edited by srcobaltss; Feb 28, 2008 at 02:27 PM. Reason: Automerged Doublepost
i probably wont do this swap. i was just seeing for one what people thought and for two how much it'd cost. i would love to keep my sc its just too much money to make it fast. and no matter what its going to be hard for the lsj to beat a turbo. i have a list of mods that i have planned on getting but they wont get me into the 12s. and the list will run me almost 3 grand. theres gotta be a cheaper way. turbo swap... yeah i could do that. but ripping off the supercharger means waranty problems and problems with inspection
But you could always keep the stock stuff and put them back on if something goes wrong.
60's 2.8, tune, nitrous, intake, exhaust tires, mounts. very low 12.
ehh..if your good thats 3000ish dollars
WHAT 13.5-13.7 ive done much better than that with my mods and dr... but yes you should deff go with a turbo kit for the lsj and make 300+whp on pump gas tune!!!
13.5 13.7....your LNF is going to take some work for that too considering its maxed in almost every way
13.5@108 with the stock tires..
Take your LSJ for what its worth. Its pretty quick from the factory. If you want a subtle mod that the dealers probably won't notice, get the TVS and build from there. The M62 is the problem of the LSJ.
Honestly man, if you wanna get into the 12s pretty easy....go out and buy an Evo, MS3, SRT-4, or STi. More power stock, much larger aftermarket.
truth.
suppose it's a direct swap, which it's not. so you're going to spend thousands of dollars, to still be in the 14's, and then STILL have to spend all the money on upgrades? wouldn't it just make more sense to buil dyour lsj?
if i keep it supercharged i'll have 2.8,stage II belt, 42 injectors, HE, nitto invos, I.T.D., ttr tranny mounts, injen intake, slp loudmouth II full exhaust(questionalbe) hurst short throw, and a tune. thats no lower then a 13.5 you can argue it but i highly DOUBT thats 12's or under 13.5
