Stage 1/2 PCM Question
So I am under the influence that the GM Stage1/2 PCMs are pretty much the same. Regardless of whether this is true or not, here's a question;
Any one know what exactly the PCMs for each stage kit are tuned for, besides the increased redline?
i'd like to add a couple specific q's:
0. Is the supercharger running at maximum boost stock? (is the boost control system bleeding off boost at full throttle?)
1. Does the stg 1 tune increase the allowable boost?
2. anyone have any dyno charts with whp, wtq, A/F ratio and boost comparing stock vs. stg 1?
Stage 1 computer is tuned for a higher redline and the 42# injectors.
Stage 2 computer is tuned for the higher redline, 42# injectors and smaller 3.1" pulley.
So no, the tunes aren't the same as w/ the smaller pulley on the stg 2 tune, timing gets advanced slightly.
Yes, the blower is running maximum possible boost for the 3.35 pulley that is stock, it doesn't get bled off. Did I miss anything? Lol
Oh yeah, upgrading to stage 1 is a waste of money. Hp gain is only like 10 or 15hp at most. Afr's suck cuz gm tunes run rich as hell
I would have to dissagree with that statement. Not to call anyone out. But I am sure that there are some people here that have installed aftermarket boost controllers and have achieved more boost. Not a whole lot more, but more.
oh so this thread is like a european roundabout?
sweet! I just entered and am on my first lap. I'll just stick to the outside lane so I dont get 2nd or 3rd lap around.
From my very limited understanding of what stg 1 entails, [opinion]I think the stage 1 kit is barely useful and somewhat misleading. It sounds like the 205-230hp bump is all near max rpm, so unless ur planning on driving near the rev limit all the time ur never gonna use it.[/opinion]
unless of course it does add some timing.
You are correct about one thing. GM Stage 1 only increases peak power, so when you are driving normal you wont feel it. When you open it up, you will feel the car pull slightly harder from 6,000 rpm to redline (7,000 rev limit).
To everyone in this thread that still can't grasp the fact that the GM Stage Tunes are identical for GM Stage 1 & 2 give up already. They are the same tune.
GM Stage 1's tune ("GM Stage Tune") adds timing. The only difference between GM Stage 1 & GM Stage 2 is the pulley. Place a 77.9mm pulley on GM Stage 1, and BAM you have GM Stage 2. GM Stage 1 does increase performance. It was tested by GM to knock 0.3 of the Cobalt SS/SC's 1/4 miles times.
Sorry if I started another war...
Ok, well anywhere spark advance is increased, torque is increased but so is propensity of knock. To counter knock you run it richer.
So is the GM stg1/stg2 map richer than stock across the cells you'd be traversing in the powerband?
THis is true!!! I bought the Stage 1 to 2 kit because it comes with an autorization code. I don't even have Stage 1, I bought used injectors, the stage 1 to 2 kit ($350) and it came with an authorization code. Why this is, I do not know, but I'm getting it installed tomorrow. GM failed on this one.
Iceberg
Sep 29, 2015 12:33 PM
