Stage 2 283hp And 243tq
http://www.gm.com/company/gmtunersou...hats_new.htm#1
Scoll down it has the stage two kit, I'm not sure if that is crank or wheel
GM Performance Parts will offer separate Stage 1 and Stage 2 supercharger kits. The Stage 1 Kit includes higher-flow fuel injectors and an ECU calibration to provide a 31 hp boost to the Cobalts engine for a total of 236 hp and 205 lb.-ft. of torque. Add in the Stage 2 Kit, with its smaller supercharger pulley and drive belt, and the engine comes alive with 241 hp and 218 lb.-ft. of torque across a broad engine speed range.
Originally Posted by JCswoosher2
im think that a HYBRID supercharger is not the one we have on our car.
Originally Posted by Brian MP5T
283hp even if that isn't a misprint, . That has to be the crank unless the internals have been swapped.
twincharged is running on stock internals and pushing over 350whp est. and over 20psi all he's done is head gasket and new headbolts. everything else is external
look closer
take a closer look the 283 hp numbers are from the time attack cobalt. that is not the stage two numbers. they are talking about the time attack cobalt that roasted all those cars in that speed vision show. then they talk about the staged kits in the next unrelated paragraph.
I heard its actually GM Stage 2.5 Type-R tune. The secret is tiny cambodian swamp rats sealed into the pulley. When you get on it they start running and make the pulley spin so fast that the motor frees up horsepower. At the exact moment the a siberian house fly jumps on the boost bypass valve keeping it closed for the forthcoming 34135314324810^5154 psi of boost...starting 100 rpm before idle!!!!!!!!!!!
Dan
Dan
alright correct me if i read this wrong but...stage 1 is 236 and 2 is 241...from what I see one of the differences is a smaller pulley....i always thought youd get more friggen....6 ponies from a higher boost...i dont know though, im still in college getting my mechanical engineering degree, havent learned about that just yet.
