Stage 2 Cobalt Running like a dog
Old Sep 18, 2012 | 01:16 PM
tonyfabo's Avatar
Exclamation Stage 2 Cobalt Running like a dog
So I recently got a cobalt ss/sc g85 with stage two. I noticed that it wasn't pulling like a stage two should. I took it into the shop they replaced the thermostat, MAF, and an o2 sensor cured the engine light problem but car still didn't pull like it should. I would get the correct 15lbs of boost but no pull. My buddy had said that it might have a clogged cat so we pulled an o2 sensor out to make an exhaust leak to see if the power had increased and still nothing. Any ideas on what this could be? It seems to me like it's an airflow issue somewhere whether it is actually still a clogged cat or if its something else like my intercooler. Help please. Everything on the car is stock besides GM stage2.
Old Sep 18, 2012 | 01:23 PM
rivaladore's Avatar
Make sure your intercooler pump is working. If your cat was clogged you'd be over boosting a few psi. And gm's canned tune isn't going to be that great anyway get a custom hpt tune.
07LSJ's Avatar
Is there anyone around you with HP tuners? They can data log your car there Make sure the tune is ok and then look at other problems like heat exchanger messed up, or intercooler pump not working.
Old Sep 18, 2012 | 01:32 PM
startingline05's Avatar
what he said
Old Sep 19, 2012 | 12:40 PM
tonyfabo's Avatar
The dealer checked my tune to make sure that it was good and they even reprogrammed to pcu so that isnt the issue i dont believe. Also to the over boosting i have hit 18 psi.
Old Sep 19, 2012 | 12:42 PM
TommyP's Avatar
AWD > FWD
If you're overboosting your cat is most likely clogged.
Old Sep 19, 2012 | 12:45 PM
jonathan923's Avatar
this^^^ and check you ic pump
Old Sep 19, 2012 | 12:51 PM
tonyfabo's Avatar
alright ill check it out if that doesnt work ill post again thanks everyone for the help!!
Old Sep 19, 2012 | 02:35 PM
Vander Nars's Avatar
If ur cat is clugged dont order another stock one waste of money get a zzp downpipe or just cut out that obe for a temp fix, catless will sound like **** tho.
Old Sep 19, 2012 | 06:35 PM
ULWizSS's Avatar
yeah i would check you ic pump and take a look to see if the cat is clogged.
Old Sep 26, 2012 | 09:39 AM
tonyfabo's Avatar
yeah i plan to order a full zzp exhaust, long tube headers, 3 in DP and 3 in exhaust. thanks for all the help. Does anyone know about any good shops to get a tune in Milwaukee area? I found shops that tune obviously but i can't find any that have good tunes for the LSJ.
Turbo Johnny
Feb 21, 2019 09:41 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
Sean Cummings
Sep 11, 2015 09:35 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
NoBalt123
Sep 4, 2015 07:10 AM
