Stage 2 dyno (crappy)
Old Oct 1, 2006 | 09:21 PM
purevl's Avatar
Well i finally dynoed the cobalt for fun, it didnt do well at all. I dont know how you guys are making the numbers around here. I made 224hp 209tq with
injen cai
gm stage 2 15psi
gmpp catback
A/f was a solid 11.5, i did my pulls in 4th gear all the way to 6500
I made the pulls in 4th gear from 4k to 6500(7k took forever and didnt do much more). What do you guys think? Did I pull in wrong gear, is there anything i should look for. I attached the graph. Seems odd since people are posting 215 all the way to 230 bone stock and i cant get that with mods. Help
Old Oct 1, 2006 | 09:23 PM
sethallen's Avatar
remember...no two dynos are the same...the dyno you used could under estimate
Old Oct 1, 2006 | 09:26 PM
carbombss's Avatar
Old Oct 1, 2006 | 09:34 PM
purevl's Avatar
We dynoed 30 cars on it today, and i use it for my other cars, its on the money.
Old Oct 1, 2006 | 09:38 PM
D4u2s0t's Avatar
did you dyno before the stage 2??
Old Oct 1, 2006 | 10:17 PM
purevl's Avatar
unfortunatley no, but there is enough data here to get an idea of my gains, i would think? Some advice i got is that my gmpp is kinda crappy for the stage 2
Old Oct 1, 2006 | 10:21 PM
NightriderCobaltSS's Avatar
Got my Dyno yesterday and they did all my pulls in third not 4th an from the dyno he only went to 6500 you can go up to 7 grand.
Old Oct 1, 2006 | 10:32 PM
buff_SS's Avatar
Strong TQ curve!
Old Oct 1, 2006 | 10:34 PM
KangolRiot's Avatar
hey where do u get dynod? I just got my stage 2 installed and also got 1 step cooler plugs from the last time I dynod.. and I hit like 214 on a mustang dyno with just a cai which is quite a bit underrated from a dyno jet reading which would prolly put me in the high 220's and I got like 209 tq also.. so Ill go down there sumtime and see how my car does there just to see if its the car or soemthing
Old Oct 1, 2006 | 10:35 PM
KangolRiot's Avatar
Im really curious what Im putting down now too since I finally got stage 2
Old Oct 1, 2006 | 10:39 PM
i am getting 241whp and 219tq. really want to get the PB 2.8 and add some tuning see what i can do
Old Oct 1, 2006 | 10:43 PM
KangolRiot's Avatar
yea my guess is I should be pretty close to that on a dyno jet with the stage 2 and cai since I wasnt too bad b4 on te mustang dyno when pretty much stock and running alittle rich with the wrong plugs at that time-
Old Oct 1, 2006 | 11:30 PM
purevl's Avatar
dez racing in seekonk
Old Oct 1, 2006 | 11:31 PM
purevl's Avatar
it was barely moving once it was up that high, i know it goes to 7k but i dont think there is 20 missing hp at the top...or is there? I will spin it to 7 next time but i doubt thats the issue.
Old Oct 1, 2006 | 11:32 PM
purevl's Avatar
Originally Posted by buff_SS
Strong TQ curve!
ya that looked pretty good, who knows maybe there is 10-15hp at the 7k mark...i will have to retry
Old Oct 1, 2006 | 11:35 PM
rukkee's Avatar
These might be dumb questions but what was the temperature and humidity the day of the pull's . How about elevation?
Old Oct 1, 2006 | 11:51 PM
RJSS's Avatar
I don't know if not running it to 7k is causing your low numbers but my stock balt hit 215 at 6350, but only 200 at 500rpm less. So it is a possibility since the hp curves are so linear.
Old Oct 2, 2006 | 12:06 AM
purevl's Avatar
thank you for that info
Old Oct 2, 2006 | 12:07 AM
purevl's Avatar
it was cool and raining all day, definetly some humidty. It was about 60
Old Oct 2, 2006 | 01:15 AM
2K5SS/SC?'s Avatar
You need to do the pull all the way up to 7000rpms. The car builds power all the way to redline. Don't feel bad as my 2.8 with Stage 2 intake and exhaust faired only 214whp and 190ish torque on a Mustang Dyno. The torque curve was insane though with 155 ft lbs at 1800rpm. Horsepower sells and torque moves!
Old Oct 2, 2006 | 06:20 AM
sheek360's Avatar
With out having a baseline done before stage two, then there really is no way of knowing what the gain was. You shouldve taken it to 7k atleast man, just to see if the car was protecting itself with its piston protection. Eitherway man, good numbers!
Old Oct 2, 2006 | 07:58 AM
purevl's Avatar
ya the more i look into it the more i see i left about 10hp on the table, just hard to believe it makes power all the way to7k, esp fro how slow it revs on the dyno.
Im well aware dynos act differently also, i know this dyno is dead on, considering we were doing a camaro dyno day, not to mention the car in my sig I have done this a few times guys
THanks for all the suggestions, I just wanted to make sure there wasnt something else. I checked my flash as well and i have the latest already. It is what it is, and its correct it seems
Old Oct 2, 2006 | 08:39 AM
BLKSS's Avatar
Holy torque! Sure likes that intake.
Old Oct 2, 2006 | 02:17 PM
KangolRiot's Avatar
hey mike let me know next time u go.. if its under $70 Ill go get mine dyno'd.. if its more than that Ill prolly just go to where I normally go... enhanced street perfromance in sterling
Old Oct 2, 2006 | 02:22 PM
plyboy-illest's Avatar
somethign is wrong.... but im sure its cuz you never got it to the 7k like everyone else said..and if thats not the case then id bring it back to the dealer... and make sure they did the flash right and everything else...
