stage 2 hp?
Old Mar 11, 2008 | 12:58 AM
jvc06sc's Avatar
stage 2 hp?
When gm rates the stage 2 is it based off their 205hp rating or the actual 215-220? In other words when it says that it boost the engine from 205 too 246, are you really only getting around 26 extra hp because the engine is underated in the first place?
Old Mar 11, 2008 | 01:00 AM
EceSSiveMod's Avatar
no your getting the 40hp.....they just say 205hp as a standard or w/e u wanna call it, most ppl dyno 212-215ish stock
Old Mar 11, 2008 | 01:03 AM
firemanfrank's Avatar
Very good question.
You're a thinker!
So if I understand you correctly then, you are saying that Stage 2's dyno 250-255hp.
Right?
Old Mar 11, 2008 | 01:06 AM
just depends on the car i think......i know a decent amout about these cars but there are other people that know way more so anyone please correct me if im wrong
chris88z24's Avatar
Theoretically, yes.. since 215 + 40 = 255hp
Anyone have stage 2 dyno numbers to compare?
Old Mar 11, 2008 | 01:09 AM
Hiya chris!
I'm gonna do a search right now for Stage 2 dynos ...
Old Mar 11, 2008 | 09:44 AM
I didn't search every single post relating to the word "dyno" (there's way too many!), but I found this thread pretty interesting:
https://www.cobaltss.net/forums/show...highlight=dyno
Modified Mag did a test where they got an additional 24hp with Stage 2 installed.
So if the Stage 2 kit makes 241hp, then our car's REAL stock hp numbers are 217hp.
12hp more than the 205hp Chevy claimed.
Makes sense ...
Old Mar 11, 2008 | 09:47 AM
QuikSilverSS's Avatar
I say stage 2 is about 235whp
Old Mar 11, 2008 | 10:06 AM
Why not 241hp?
Old Mar 11, 2008 | 10:47 AM
Originally Posted by firemanfrank
Why not 241hp?
I had buddies with stage 2 only dyno around 235whp...I mean its depentant on alot of factors but on average 230-240whp
Old Mar 11, 2008 | 11:46 AM
rnjmur's Avatar
The 241 HP is crank HP, not wheel HP. on a dyno you would typically expect to run about 220 to maybe 230 wheel HP on a dyno with just stage 2 and no other mods (you can't dyno crank HP numbers unless you are going to pull the motor). If Modified Mag claim they got a 24 HP increase that would be at the wheels, then they probably gained about 29 HP at the crank. Everything is relative; each car is different and every dyno is different.
Old Mar 11, 2008 | 02:05 PM
jvc06sc's Avatar
Thanks for the clarificattion guys. The link that you put helped alot firemanfrank thanks for the help!
Old Mar 11, 2008 | 08:33 PM
Your welcome!
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
