Stage 2 installed, rpms "hanging"
Old Aug 30, 2008 | 05:55 PM
BaltZ SS's Avatar
Just got the Stage 2 kit installed on my 06 ss/sc and I noticed now when I shift as soon as I push the clutch in with my foot completely off the gas the tach shows a small increase in rpms (about 100) where it stays for a split second and then drops. Anyone else experiencing this? Just wanted to know if its normal or not.
Old Aug 30, 2008 | 05:57 PM
Raven SS's Avatar
do u feel it with the engine also or just a gauge thing? faulty gauge maybe
Old Aug 30, 2008 | 06:04 PM
BaltZ SS's Avatar
I'm pretty sure the gauge isn't faulty, before Stage 2 the rpms used drop right away when pushing in the clutch. It doesn't go up that much and it doesn't take that long before it drops again (maybe half a second) its just something I have to get used to because it has thrown my timing off a little bit. My brother's 05 ss/sc does the same thing but he's on the stock tune.
Old Aug 30, 2008 | 06:05 PM
EatonTVS07's Avatar
mine use to do that but it went away
Old Aug 30, 2008 | 06:08 PM
theneelster's Avatar
Sounds flywheel/clutch related but there's nothing in the stage 2 tune that would do it...maybe you're just noticing it now.
Old Aug 30, 2008 | 06:27 PM
EatonTVS07's Avatar
maybe throttle body clean.....
Old Aug 30, 2008 | 06:29 PM
Sharkey's Avatar
my rpm kinda hangs and slowly comes down. never figured out why, dont really care.
Old Aug 30, 2008 | 06:30 PM
EatonTVS07's Avatar
^ you should clean your tb and see what it does from there, hows it idle
Old Aug 30, 2008 | 06:35 PM
Mss26's Avatar
There is a known issue with some tachs being slow/lagging in 1st and 2nd gear after stage 2 is installed.
so it just be that... try it out in 3rd gear and if it still does it then you have a different problem
Old Aug 30, 2008 | 06:38 PM
WickedSS2005's Avatar
The tachs lag on custom tunes too. My limiter is 7300 but the one time I hit it, HPT scanner showed 7496 rpm
Old Aug 30, 2008 | 06:41 PM
Zach06CobaltSC's Avatar
and you wonder why you have a valve making some noise tom, i mean your "torque dampener" making noise.
Old Aug 30, 2008 | 06:42 PM
BaltZ SS's Avatar
Idle is fine, 875 rpm, no blips or shakes.
Old Aug 30, 2008 | 06:46 PM
I only go to 7100 rpm MAX on tha tach if I feel like it
Last edited by WickedSS2005; Aug 30, 2008 at 06:46 PM. Reason: Automerged Doublepost
EatonTVS07's Avatar
maybe it is your tach then, can you feel the engine staying up high after you shift
Old Aug 30, 2008 | 06:50 PM
BaltZ SS's Avatar
Yeah the engine sounds like I'm still giving it gas but my foot is off the pedal.
Old Aug 30, 2008 | 07:07 PM
EatonTVS07's Avatar
maybe its just the tune then i dunno
Old Aug 30, 2008 | 08:40 PM
rukkee's Avatar
I might need some time to relearn certain parameters on the car after the stage tune
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Sep 28, 2015 02:46 PM
DocSvensk
Sep 27, 2015 02:24 PM
