Stage 2 Kit- and and Replacement 2.79" Pulley?
Well I was exploring cobalt-addiction.com and noticed they have a 2.79" replacement pulley for the GM stage 2 hub. Now it says it will work with the Stage 2 Reflash and everything, but i'm wondering if it will be fine on the 42lbs injectors?
I would say only going to a stage 3 pulley (3.06") comfortably. 2.9" would be cool, but I would say you need engine monitoring to make sure everything is in check. Under that, and you need a tune IMHO
^ I agree 100% I would not go smaller then a Stage III GM pulley on the GM stage II reflash. Just IMO though. And you won't really see much of a gain on that small of a pulley change.
patooyee
Oct 1, 2015 01:07 PM
