Stage 2 problem(i think)
Old Mar 19, 2008 | 04:56 PM
  #51
phatnackySS's Avatar
could be somthing wrong with the boost bypass actuator ....do a boost bypass-bypass and see what happens .
  #52
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by Barhi
I did buy it from GM not ebay and it does have 4 bolts on it so it is the smaller pulley. But they did not give me my old one back. So I am taking my car to another dealership just to make sure every thing was put on right. If that does not work I will be buying a new 2.9 pulley.
Go back to the dealership and request ALL of your old parts back. Those are YOUR parts, you paid for them when you bought the car. If they say that they don't have them anymore, then tell them that they need to buy you new ones.
Those injectors, pulley, and belt can catch you a good pocket of money if sold... among other things.
Originally Posted by rallyracer
Im running the 42lb injectors on stock tune untill I get my flash.
Is this bad and will it **** up my engine?...I do have a CEL right now
It's not "Bad"... but it isn't "good". You aren't going to blow anything up... but you aren't going to be running as good as you should. Just stay out of the throttle.
Originally Posted by Mss26
okay don't shoot me for saying this but i just had my stage 2 installed and flashed by gm.. car runs fine, is faster.. but no 7000rpm rev limiter.. apparently the latest update to the flash does not have a 7000 rpm rev limiter and leaves it at stock 6450...
This is according to my GM delearship after 2 days of them trying to figure out my problem as well as the people on the GM techline who confirmed the flash has recently been updated.. and i'm in canada but that shouldn't make a difference.
Call GM to verify. I think they are talking out of their asses. KEEP YOUR INSTALL RECEIPT, if GM says that it should increase the Rev Limiter... then report the Dealership for a bad install (aka being idiots).
Old Mar 19, 2008 | 04:58 PM
  #53
Mss26's Avatar
yah problem is I can't find the right number.. i've tried a couple but they have no clue and don't know who to transfer me to
Old Mar 19, 2008 | 05:07 PM
  #54
Did you call 1-800-263-3777? That's the Canadian Customer Assistance Center.
Ask to speak to someone KNOWLEDGEABLE in GM Performance Parts or GM Accessories.
I'm almost 100% sure that you should still have a 7k redline.
Take it to another dealership and ask to speak to the Service Manager. Take your paperwork (ie Stg2 instructions, receipts) with you. Tell him/her that you suspect the other dealership of doing a bad install. See if he /she will work with you, he/she should.
The main thing to check, obviously, is the Flash. Just ask him/her if they will check to make sure that you have the Stg2 flash registered to your VIN #, and if so, to make sure that it is indeed on your car.
If all else fails... find someone with HPTuners that lives near you.
Old Mar 19, 2008 | 05:13 PM
  #55
srowler9's Avatar
First off, I had my stage 2 put on 3 months ago, and the redline definately went to 7000 rpms. The boost is around 15 psi peak.
Secondly, just measure your pulley size. It should measure in at 77.9mm.
here is all the info on stage 2.
http://www.crateenginedepot.com/stor...-P1540C41.aspx
Old Mar 19, 2008 | 05:25 PM
  #56
BLKblurr06's Avatar
Hi everyone i am really new here and I have a quick question. I just had stage 2 installed on my ss and I can not seem to get past 12psi boost. At about 5k rpm it gets to 12psi and will stay there until red line. Has anyone else had this happen to them if so what did you do to fix it? Or is there even a problem?
If you hit 12 psi at 5K RPM then you are boosting sooner than stock, It is VERY possible that GM's latest update for the reflash allows earlier boosting, but levels off boost once 12 psi is achieved...
Old Mar 19, 2008 | 05:30 PM
  #57
Boost By-Pass mod will tell all.
Old Mar 19, 2008 | 08:33 PM
  #58
qwikredline's Avatar
The stage 2 should go to 7000 i was wrong saying 6400; the boost max is 14.5 @ 7000 and max power is around 6500...all this on css.net faq
Old Mar 19, 2008 | 08:45 PM
  #59
idunn's Avatar
possibly a bad boost gauge, dyno that bitch
Old Mar 19, 2008 | 09:37 PM
  #60
Barhi's Avatar
I don't really know how to do a boost by-pass but i will look it up and see what I can do. I found a shop in town the works on supercharger's, so I will see what they tell me and I am going to have them dyno it to. So I should find out tomorrow I hope. Thanks for all the help everyone. I will post back with what was wrong if any thing.
Old Mar 19, 2008 | 10:16 PM
  #61
Mss26's Avatar
my stage 2 was installed last week and i hit 14.5-15 PSI pretty much from 4500 onwards in 2nd....
and as i mentioned previously though.. my rev limiter is still 6450..
i'm confused too
Old Mar 19, 2008 | 10:27 PM
  #62
Bman21106's Avatar
i hit 13.5 with just an intake lol...get that checked out again... sucks man
Old Mar 20, 2008 | 01:06 AM
  #63
Barhi's Avatar
i'm confused too
Lol at least I'm not the only one.
"i hit 13.5 with just an intake lol...get that checked out again... sucks man"
Some people have all the luck I am getting it looked at by a supercharger shop in town and plan on taking the bill to GM when they find out whats wrong.
Old Mar 20, 2008 | 09:55 AM
  #64
One more post on this from me and thats it. If there is air in the aftercooler system, you wont get full boost if the Inlet Air Temperaturet is higher than the ecu algorithm permits; as one poster said the inlet gasket can be put back wrong it happens a lot its an easy mistake. If you dont fit the larger remote reservoir you will NOT get maximum stage 2 performance expecially in hot places like Texas...please stop slamming the dealers, they dont get allowed enough time flate rate to do the job like it should be done and you folks dont want to pay straight time...and as peak power is at 6500 frankly using 7000 is a waste so dont cry....good luck Barhi send me a PM if you still feel you are in trouble and I can refer you to folks in Texas who can help u depending where you live its a big state....
Old Mar 20, 2008 | 10:14 AM
  #65
Barhi's Avatar
Thanks man, I am not slamming the dealer to hard but I did pay over $300 for them to install it. So am not to happy with them, its in the shop am the moment so time will tell.
Old Mar 20, 2008 | 08:51 PM
  #66
Mickaroo7's Avatar
Dude that suck I just got my stage 2 as well i'm hitting at least 16 to 17 psi with a cai. But as another person said on this forum the rev limiter is still at 6500 rpm not 7000 rpm. I'm not sure if there was an update to the flash or what but I have read other people who have had a problem with it as well.
Old Mar 20, 2008 | 09:11 PM
  #67
QuickSilver_SS's Avatar
I had my stage 2 installed only 3 weeks ago. My rev limiter is now 7000rpm ? I'm not sure why they would change the rev limiter back to the 6500rpm ? It's deffinetly something to look into for sure.
Old Mar 20, 2008 | 10:04 PM
  #68
BY the way the stock tach needle lag is pathetic, like most analog gauges in most cars, so i put in the OEM optional RL shift light ladder tach (way kewl) and i dont have to look anymore at the needle it doesnt matter. and shifting at best power dropping to best torque when you shift works best, so 7000 is a waste . But i can adjust the shift lites if i want! I think even if the new flash has changed down to 6500 its ok. The main thing is Bahri wants his boost and he should have it...hopefully all will become clear soon and he will be a happy camper good luck in texas...i sure hope the car isnt running high IAT's and that why he cant get boost...
Old Mar 20, 2008 | 10:43 PM
  #69
Mss26's Avatar
a local guy has just offered to scan my car with hptuners to see whats up with this "new" flash and find out if that is the reason my rev limiter is still 6450...
there seems to be a few more people popping up with recent stage 2 flashes that are stuck with this 6450..
i'll post the results as soon as i get them
Old Mar 20, 2008 | 11:22 PM
  #70
Wrong.
My Intercooler Pump went out and all the coolant boiled out back in October... I went from hitting 16 or so psi to hitting 18 psi like it was nothing. The higher the IAT's... the higher the Boost Pressure.
Old Mar 21, 2008 | 09:18 AM
  #71
wow that amazing. I guess if thats correct we should all drain our coolant and get max boost? I assume you have something other than a stock GM cal 'cause the protections are built in by GM and what you describe "aintgonnahappen.com" ...time to leave this thread...
Old Mar 21, 2008 | 10:14 AM
  #72
I was hitting full boost... BUT the protections that are in place on the ECU are to pull timing not boost. My car was pulling timing like a MOTHER.
And just because you are pushing more boost doesn't mean that you are going faster.
Old Mar 25, 2008 | 10:45 AM
  #73
Barhi's Avatar
UPDATE**
I still dont have it fixed everyone keeps saying the same thing "their is not a problem". They have checked for leaks and what not. By-pass valve is working fine so I really dont know what else it could be. One more question for you all. The new flash that we got for stage 2 does it have any thing to do with moving up the max boost?
Old Mar 25, 2008 | 10:56 AM
  #74
UPDATE**
the ecu dose controle boost, thats why many have said to bypass the bypass valve...its not a case of if its not working...its a case of if it is working.
the best way to tell if the ecu is limting boost is to bypass the valve...if you do that and you see more boost...then you have your answer.
how too...for the satrun fourms
Plugging the line coming from the Intake Manifold to the solenoid and leaving the solenoid nipple open to the air.
what it lookes like stock
what it will look like after.
im not saying to keep it like this, im just useing it as a diagnostic tool....now go out and do it...un-plug the line from the solenoid , and stuff somthing in the line just for now ...and give it a drive ....
if it builds full boost ...then eather the ecm is limting boost for some reson, or the acutuator isnt working as it should.
if it dosnt build boost...then you can elimnate the actuator ,and ecm as a problem...then you can move on to the next thing.....simple prossces of elimination
Old Mar 29, 2008 | 08:44 PM
  #75
Barhi's Avatar
Update**
Got the problem fix, it was the boost gauge that was bad. I had a new one installed and i'm at about 17psi WOOT.
