stage 2 psi
Old Jan 24, 2008 | 09:14 PM
Inferno's Avatar
stage 2 psi
how many pound should i expect to be boosting with just stage 2?
ColeJJones's Avatar
Bannned
i hit around 16-17
Old Jan 24, 2008 | 09:15 PM
BLK SS/SC's Avatar
dpont have it yet but 15-16 from what ive heard
boostedss26's Avatar
i was hittin 18
Old Jan 24, 2008 | 09:22 PM
Badju587's Avatar
Two answers:
1. Search Button
2. Varies with altitude (I'm boosting 12.5 at 5,000', sea level is 15-ish). If you're somewhere in between, figure 1/2 pound less than sea level rating for every 1,000 feet up, that should get you somewhere close.
Old Jan 24, 2008 | 09:23 PM
RJSS's Avatar
It's all dependent on your altitude and the weather conditions (in general colder=more boost) however from what I've seen:
stage 2 w/ stock exhaust - 15-16 lbs.
stage 2 w/GMPP or aftermarket exhaust 14-15
I usually run in the 15's but the highest I've ever seen was 18lbs. at 7000rpm in 3rd with an ambient temp. of 3 degrees outside. Also, if you really want accurate boost numbers you need to get an Interceptor gauge because the stock gauge is hard to read and gets inaccurate at the top end.
PS-A rough calculation that works for the SS/SC is 1lb of boost for every 0.1" decrease in pulley size
Old Jan 25, 2008 | 12:34 AM
ColeJJones's Avatar
Bannned
i have full bolt ons and 2.9 and hit 17 maybe 18 tonight. cant really tell with stock boost guage
Old Jan 25, 2008 | 08:42 AM
Texas SS's Avatar
boostin max about 15 Psi
Old Jan 25, 2008 | 08:59 AM
Herndon_High_SS's Avatar
14 and then 15 up at redline in the summer. In the cold 16-19 in winter 20degrees. Stock pulley.
Old Jan 25, 2008 | 11:21 AM
Kibosh3's Avatar
15-ish psi
Old Jan 25, 2008 | 11:39 AM
roadrage06's Avatar
i haven't had my stage 2 in the summer yet, but i'm like Herndon high SS. We've seen mid teens and low twenties lately and i've been hitting (average) 15psi... I top at 16.5/17
Old Jan 25, 2008 | 09:42 PM
Jephron's Avatar
I have an interceptor and the highest I've seen is about 16.2 on that
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Sep 27, 2015 08:53 PM
