stage 2 question
Old Apr 18, 2006 | 08:40 AM
fifasf's Avatar
stage 2 question
I drive a lot for work and now that a bunch of you have gotten the stage 2 I wondering what kind of decrease in gas mileage we are looking at. Thanks
Old Apr 18, 2006 | 08:45 AM
NJBLUESS's Avatar
I drive 100miles round trip/day. Only seen 1mpg lower since install.
Old Apr 18, 2006 | 08:51 AM
c7015's Avatar
Serriously
Old Apr 18, 2006 | 08:52 AM
R33P3R007's Avatar
360 L337 User
Originally Posted by c7015
Serriously
W3RD
Old Apr 18, 2006 | 09:01 AM
CobaltSS422's Avatar
No difference. drove about 150miles from Buffalo, NY to Syracuse, NY and back and was getting 31mpg.. City driving is the same before Stage 2 between 25-26mpg
Old Apr 18, 2006 | 09:07 AM
plyboy-illest's Avatar
i think as long as you dont punch it every time you wont see that much of a difference... given you will see some ther eno stoping it because of the bigger fuel injectors but it wont be that much of a difference if you dont punch it all the time...
Old Apr 18, 2006 | 09:16 AM
It's funny though.. When you do punch it you can watch your mpg go down and when u sit idling it goes down.. never did that before the larger injectors
Old Apr 18, 2006 | 09:45 AM
CTCOBALTSSS's Avatar
Not much difference at all.
Old Apr 18, 2006 | 09:53 AM
Nauticabri's Avatar
Agreed, very little diference under normal driving, at WOT.... the results will be obvious, but they were stock too
Old Apr 18, 2006 | 10:20 AM
2K5SS/SC?'s Avatar
I went from 20ish up to 24 actually. I seem to get better mileage now. Get on it, and it will go down a little obviously.
Old Apr 18, 2006 | 10:40 AM
mken's Avatar
I reset the mpg when I picked the car up, went out and abused it a little, and it hasn't dropped below 28 mpg yet. Close to 100 miles of much more "spirited" driving than normal, it's kinda wierd.
Of course, something's not right with mine anyways. I've got the 7k rpm limit but the car almost feels like it sputters below 3k rpms, now, like I need to run it that high for a smooth shift under relaxed driving conditions. No CEL's or anything, just feels like it noticeably lost power down low. I need to pick up a scanner so I can see what's going on. I have an idea, though. Anyone that remember's WopOnTour's post in another stage thread about the programming software being used, well the shop foreman left a copy of the "Service Programming System Summary" page in my car with the old parts I asked to keep. It says TIS2000 at the top and in the 8 calibration files it lists, the proper pcm calibration # for the stage kit is not listed. I have the higher rev limit, but it seems like they didnt' program everything in, if it makes sense to anyone, I'm not exactly sure what's going on. Taking a trip back to the dealer right now...
Edit/Update: Don't mean to keep taking this off-topic, but I went back to the dealer and showed them Wop's posts and how the correct calibration # doesn't even show up on the summary. The tech called the same phone # for the VCI again, and he said they weren't absolutely sure the calibration that was programmed in was the right one or not because this is all still new and they don't have solid confirmation. So they are calling GM Performance themselves and asking someone there then calling me back later to let me know. I'm hoping it wasn't programmed correctly, because below 3k rpm's is definately lacking now compared to before hurting driveability by alot.
Old Apr 18, 2006 | 12:46 PM
I just got mine done on last thursday. I definately have the 7k rev limit too because i hit it last night. but it lacks a little bottom end but it takes off once i get past 2700rpms.. Wop also said that it won't show because it's new and it may not even show. Isn't the VCI number they give you like a confirmation number?
Old Apr 18, 2006 | 12:47 PM
BLKSS's Avatar
None at all. If anything its better. The RPMs go up by themselves it seems.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
