Stage 2 question
Old Nov 9, 2006 | 10:33 PM
FNFAST's Avatar
Stage 2 question
Ummmm...is it normal to pull 16 PSI with the standard GM stage 2 kit?
Old Nov 9, 2006 | 10:34 PM
bavoose's Avatar
i am running 16 psi and i have stage 2, gmpp header, gmpp exhaust, xtc 2.5 downpipe
Old Nov 9, 2006 | 10:40 PM
Coblt ss super's Avatar
sure hope ill be running high boost with my stage 2 when i get it and member man u got taht 2.8 on there lol
Old Nov 9, 2006 | 11:03 PM
bobino's Avatar
I was running around 16psi,with stage2, Hahn header, magnaflow cat back.
Old Nov 10, 2006 | 10:02 AM
FNFAST's Avatar
ok cool...so I am not alone haha
Old Nov 10, 2006 | 10:04 AM
R33P3R007's Avatar
360 L337 User
are you just stage 2. with the 3 inch gm pulley
Old Nov 10, 2006 | 10:06 AM
FNFAST's Avatar
Yes.
I called the GM dealer yesterday about it and they said the car was WELL within parameters and was just fine.
I was just more or less curious if anyone else was pulling 16 psi with a stage 2
Old Nov 10, 2006 | 10:17 AM
R33P3R007's Avatar
360 L337 User
you may want to check you Cat isn't plugged up. mine cooked itself ad i was overboosting, and it smoked all the gasgets from there forward.
Old Nov 10, 2006 | 10:20 AM
FNFAST's Avatar
Good advice but do you think my cat would be plugged with only 500 miles on the car?
It was pulling 12 psi before I brought it in and it was pulling 16 psi from the moment I left the lot...do you think the cat instantly clogged?
Old Nov 10, 2006 | 10:22 AM
FNFAST's Avatar
The Mechanic took it for a ride with the computer hooked up to it and said all the numbers looked fine? Wouldn't the Rear O2 sensor be off if the cat was plugged?
Old Nov 10, 2006 | 10:26 AM
Edubs's Avatar
Were you seeing a little bit over 12 lately before you got the S2 installed. Only reason I ask is because it's been so cold lately, some people have been saying that they're reading a little bit higher boost.
I'm not great with science and all, but depending on your location, certain factors might change your boost levels. ie: elevation, air temps...
EDIT: After my S2 was installed I kept getting pissed because I was having a hard time hitting 15.5psi. Since it's got colder, I've seen 16-16.5psi before and after installing my intake...
Old Nov 10, 2006 | 10:28 AM
FNFAST's Avatar
That is probably it edubs...I live in wisconsin and it has been about 40 degrees out when I take my car out.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
