Stage 2 w/60s
South Central *********
Stage 2 w/60s
i have had been running stage 2 w/ the 2.8 for some time now but was wanting to upgrade injectors
can i just install the 60lbs injectors with the GM tune and it run properly, or do i need hptuners
also i have in the mail the GM dual pass and upgraded intake gaskets for a build i was planning- do you think i should go ahead and install all that soon or wait till the engine is out and being built
just need some opinions for my set up
see my fear is that if i go ahead with the install of the DP mod im going to have to replace the upgraded intake gastket (once installed) when i do the pistons/rods/studs and the head/cometic/valvetrain stuff
HPtuners is in the future but wanted a time frame to plan my mods and be prepared
best to wait and do it all at once, you think?
or should i do dual pass immediatly to safely run my current setup?
lol ^^ no. dont run 60's with a stage 2 setup. good god that is asking for trouble.
go ahead and install the dual pass. no reason not to. you will be safer, cooler, and possibly a "bit" faster
i was talking about the 60's with the gmtune. I was thinking if you go really easy on the car until you can get it tuned and you might be fine with the gm tune. But for safety reasons and too save money in the long run i would not run the 60's on the gm tune.
thanks for your input
any thoughts on the GM dual pass mods?
my input at least ^^
if you have stage 2 already look at this group buy if u want 60's
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/2-79-60lb-tune-group-buy-42011/
