Stage 2 w/60s
Old Jan 11, 2007 | 11:42 PM
JapEatr's Avatar
South Central *********
Stage 2 w/60s
i have had been running stage 2 w/ the 2.8 for some time now but was wanting to upgrade injectors
can i just install the 60lbs injectors with the GM tune and it run properly, or do i need hptuners
also i have in the mail the GM dual pass and upgraded intake gaskets for a build i was planning- do you think i should go ahead and install all that soon or wait till the engine is out and being built
just need some opinions for my set up
Old Jan 11, 2007 | 11:43 PM
yellowcobaltss05's Avatar
u definetly need hptuners to run the 60's.
Old Jan 11, 2007 | 11:45 PM
hatrickstu's Avatar
yeah you are going to need some type of tune
Old Jan 12, 2007 | 12:00 AM
JapEatr's Avatar
see my fear is that if i go ahead with the install of the DP mod im going to have to replace the upgraded intake gastket (once installed) when i do the pistons/rods/studs and the head/cometic/valvetrain stuff
HPtuners is in the future but wanted a time frame to plan my mods and be prepared
best to wait and do it all at once, you think?
or should i do dual pass immediatly to safely run my current setup?
Old Jan 12, 2007 | 12:03 AM
u might be able to do it but you can NOT go WOT at all or else your engine will go boom
Old Jan 12, 2007 | 12:23 AM
JapEatr's Avatar
Originally Posted by yellowcobaltss05
u might be able to do it but you can NOT go WOT at all or else your enine will go boom
elaborate,
I run my car WOT now and its just fine
i personally dont feel my injectors will run static on the 42.5s
or are you refering to the 60s w/ GMtune
Old Jan 12, 2007 | 12:30 AM
ReMz's Avatar
lol ^^ no. dont run 60's with a stage 2 setup. good god that is asking for trouble.
go ahead and install the dual pass. no reason not to. you will be safer, cooler, and possibly a "bit" faster
Old Jan 12, 2007 | 12:53 AM
i was talking about the 60's with the gmtune. I was thinking if you go really easy on the car until you can get it tuned and you might be fine with the gm tune. But for safety reasons and too save money in the long run i would not run the 60's on the gm tune.
Old Jan 12, 2007 | 01:00 AM
JapEatr's Avatar
definantly
thanks for your input
any thoughts on the GM dual pass mods?
Old Jan 12, 2007 | 01:03 AM
ReMz's Avatar
you should not run 60's on a gm tune period? that's... that's... lunacy :O
Old Jan 12, 2007 | 01:04 AM
ReMz's Avatar
Originally Posted by JapEatr
definantly
my input at least ^^
Old Jan 12, 2007 | 01:06 AM
no problem
Old Jan 12, 2007 | 08:32 AM
NightriderCobaltSS's Avatar
if you have stage 2 already look at this group buy if u want 60's
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/2-79-60lb-tune-group-buy-42011/
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
