Stage 3... what rpm's will the injectors go static?
Old Jan 27, 2008 | 04:09 PM
MTchevy1's Avatar
Stage 3 lets you raise the rev limiter... so if you're running the stage 3 pulley and a dry 50 shot, is it safe to raise the rev limiter? I know you need to change balance shafts and valvesprings, but I'm just talking fuel here. Is there a chance of going static with the stage 3 setup?
Old Jan 27, 2008 | 04:11 PM
07cobaltss's Avatar
i would not go over 7500 without upgrading valveterane.
Old Jan 27, 2008 | 04:13 PM
MTchevy1's Avatar
Read entire post please.
Old Jan 27, 2008 | 04:49 PM
SSdan's Avatar
Yes, there is a chance of going static, I'd say probably at 7300 or a little less.
From what I recall in a GMPP Stage 3 article, it puts the injectors very close to the limit at redline.
Old Jan 27, 2008 | 04:50 PM
Altiery54's Avatar
7250
Old Jan 27, 2008 | 05:36 PM
cobaltss2006frank's Avatar
What does "going static" mean?
Old Jan 27, 2008 | 10:47 PM
INFE's Avatar
i have the stock injectors in and at 7250 they are at 127% so yes they are going static.
Old Mar 25, 2008 | 12:39 AM
rockkrawler628's Avatar
i guess you can't plugi n in some 60lbers cause you can't tune for them correct?
Old Mar 25, 2008 | 12:43 AM
hungryhip-ccp's Avatar
nope, it states in stage 3 instructions nos is not to be used above 7k which means it will really shut down at 65oorpm keeping you inj maxxed out but not static
Old Mar 25, 2008 | 01:55 AM
syP's Avatar
syP
Full out wide open.... maxing them out...
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
patooyee
Oct 15, 2015 05:11 PM
