Stage 5 and exhaust
Old Nov 11, 2006 | 07:27 PM
Blurred Vision's Avatar
Stage 5 and exhaust
I currently have the Intense-Racing stage 5 upgrade with out the ported blower, and I have 2 question. Question 1 is what size exhaust would you guy recomend from collecter size back not just cat back the whole way motor to tip. My second question is that I had Intense remove my rear O2 so I could run cat less, but currently I have all stock exhaust, and my check engine light comes one every now and then saying bank 1 lean could the fact that I still have my rear O2 hooked up or being that I still have my stock cat on becausing this code to throw like it is? Help ease my mind please.
Old Nov 11, 2006 | 07:29 PM
JCswoosher2's Avatar
i like my full 3". the CTI exhaust is a good exhaust. thats my opinion
Old Nov 11, 2006 | 07:40 PM
Blown 4-banger's Avatar
running lean? You don't happen to have an intake do you?
Old Nov 11, 2006 | 07:42 PM
06blackg85ss's Avatar
p0171 code? thats not from the 2nd o2..... that could be ^^^^
Old Nov 11, 2006 | 07:48 PM
rear O2 sensor codes are, P0036, P0141, P0144, and i believe P0163 not sure on that one. I erase those 3 or 4 codes at least 20 times before disabling it through hp tuners.
Old Nov 11, 2006 | 07:55 PM
Ya, I have an Injen CAI, but, I also had Intense tune for that when I ordered my kit.
Old Nov 11, 2006 | 07:57 PM
And it's not on all the time it comes and goes as it pleases, like an exgirlfriend that you bang on the side.
seems like they may not have changed anything in the tune if your still running lean.
Old Nov 11, 2006 | 07:59 PM
Would a clogged cat cause it perhaps?
Old Nov 11, 2006 | 08:12 PM
no a clogged cat would cause you to make more boost, but I guess it might run you lean.
Old Nov 11, 2006 | 08:51 PM
Just took it to Autozone its a P0171 code.
Old Nov 11, 2006 | 08:58 PM
SS_SC_Cobalt's Avatar
that's the intake code.
Try getting the Maf Cleaner at autozone or pepboys made by CRC, and clean off the maf, then see what happens...
Old Nov 11, 2006 | 09:08 PM
Thanks 4 the help I'll try that tomarrow. Any more suggestions on exhaust size.
Old Nov 11, 2006 | 09:15 PM
M88ArRamadi's Avatar
1st.....Yea......that's what was suppose to happen......you have a CAI ontop of a Stage 4....careful!!!
2nd.....a stage 5 minus the ported sc is a Stage 4 w/2.5 (pcm's are the same)
3rd......That is exactly how I popped my enging...going too lean then det. then boom
Old Nov 11, 2006 | 09:19 PM
What do you suggest maybe have it retuned?
Old Nov 11, 2006 | 09:25 PM
I went to a race shop and they tuned it for the CAI. I was lucky I didn't blow it before that. Definately get it retuned (atleast fix your AFR).
Old Nov 11, 2006 | 09:27 PM
The motor was allready rebuilt once about a month before putting on the stage kit, due to a cracked piston, but a perfictaly fine head gasket. FYI I bought the car used with 18,xxx miles on it. And this first started the day that I put the stage kit on I never had it before and when I say started the as soon as I put the kit on I mean when I had the crank releared they also cleared the P0171 code for me.
Old Nov 11, 2006 | 09:33 PM
I'll probably be giving Intense a call on monday to see what they have to say because I payed for the extra tune. Plus I've been driving on it for about a month or more now, and just the other day I started it up to let a friend listen to the blower whined up and it acted like it just wanted to die, so I shut it off and started it back up and it ran fine and no code was thrown. It seems like the only time the code throws is when I driving normal everyday driving conditions. Like it just came back on today on my way home from work in fiveth gear at 65 mph and thats the first time its went off in like 3 days.
Old Nov 12, 2006 | 01:12 AM
Shermen's Avatar
i have the same problem with this code. it seems like when i drive up and down my street, its like 2 miles long 25 mph all the way, it turns on. i drive my friend home every day from school she lives on the other end of the street. on my way home it seems to come on if i just cruze. then turns off like 2 days later.
o yeah i have the intense stage 3 and a cai. didnt do it till i put the pulley on. doesnt realy bug me, but i do seem to get a power loss when it comes on. intense told me to put my factory intake back on. i was just like thats too much work for my fat ass.
hope this helps some
Old Nov 12, 2006 | 02:11 AM
eases the worrie how long has this been going on with your car. Yeah I also don't seem to lose any power just gain a dash light every so often , and if I find out any more I'll keep you informed.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
