stage kit
Old Oct 3, 2012 | 01:31 PM
matt88davis's Avatar
stage kit
i have a 05 cobalt ss/sc. i want to put a stage kit on it. i want to put zzp stage 3 but idk what set up i should do like pulley size and injectrs i would like to run the lowest while sticking with 93 octane please pitch in your opinions
Old Oct 3, 2012 | 02:07 PM
Melon's Avatar
Most of that info is on their site. I think running 93 u can go down to a 2.8" pulley. As far as injectors, 60s will b more than sufficient for the stage kit. But if ur gonna go big build farther down the line then just get the 80s. R u gettin the s3 he, dual pass and option b? Highly recommend it
Old Oct 3, 2012 | 02:17 PM
RoadconeTuning's Avatar
throw meth on the car and run a 2.5
Old Oct 3, 2012 | 03:50 PM
Drunkship's Avatar
I was thinking about keeping mine pretty mild whenever I make the jump. The closest E85 station near me is 15 miles away so I'll just be running 93. I wanted to just go with a 2.9" pulley, 60# fuel injectors and the new ZZP heat exchanger.
Old Oct 3, 2012 | 04:03 PM
blueLNFftw's Avatar
Your going to need an intake and header as well
Old Oct 4, 2012 | 12:18 AM
Bad-A-SS's Avatar
As blackSSstag2 said.... What other mods have you got done already? My setup is 2.8 n 60s, 3in intake n full 3 in exhaust, with almost all cooling mods n a very CONSERVATIVE TUNE and I dynoed 250hp n 230tq with the clutch shitting on itself lol
Old Oct 8, 2012 | 09:45 PM
i hvae a new injen intake and a dual apexi exhuast. idk if the header was changed. i am thinking bout ding stage 3 with a 2.8 pulley and 60 injetors. So i just need dual pass end plate and heat exchanger?
Old Oct 9, 2012 | 06:11 PM
blueLNFftw's Avatar
depends. find out what header is on the car.
also, i can guarantee that exhaust is ricey as ****, I would replace that too.
Old Oct 9, 2012 | 11:18 PM
exhuast sounds nice its deep not like a fart can but how do i see if the header was replaced?
Old Oct 10, 2012 | 12:25 AM
Vander Nars's Avatar
Just look at it or take a pic and post it here
Old Oct 10, 2012 | 05:43 PM
steve1213's Avatar
dont buy a 3'' exhaust if you run only a 2.8 cause you lost power 100% sure you can stay with your stock one or 2.5'' afthermarket with a 2.8 pulley. buy a cold air intake with your stage 3 zzp if you think only run a 2.8 you can take a 60 injector, heat exchanger zzp, dual endplate etc.. and add a option B seriously. and afther go on dyno bellow 2.8 pulley is a + if you buy a meth kit
Old Oct 16, 2012 | 09:41 PM
the header has a gm part number so i think its stock and the exhuast is 3in what pulley should i run with that for best performance?
Old Oct 16, 2012 | 09:56 PM
Bad-A-SS's Avatar
Just run a 2.8 just to be on the safe side like others have said. But if you wanna make some more power grab a meth kit since OTTP is having some great deals on their stuff and pulley down to a 2.6 pulley this usually help gain some great torque numbers too
Old Oct 16, 2012 | 09:59 PM
Pedobear's Avatar
wait for the stage WTF to come out
would i have to get a new header and exhuast doing the meth kit?
Old Oct 16, 2012 | 10:10 PM
where should i get the stage kit zzp or ottp and whats option b
Old Oct 16, 2012 | 10:19 PM
and what header should i get?
Old Oct 16, 2012 | 10:57 PM
BankerBalt's Avatar
Bad mab header. Go through zzp. I'd suggest getting a legitimate tune tho
Old Oct 16, 2012 | 11:23 PM
Bad-A-SS's Avatar
Yeah just go ahead and get a header. I have the Badmab and I am amazed at the quality honestly and it makes the power and is dyno tested plenty of times. ZZPs stage kit just seems better pieced together and it all FITS. If you have any ?s about it dont be afraid to pm me
Old Oct 17, 2012 | 09:30 PM
thank you Bad-A-SS you have been a big help if do have questions i will thank you again im only 18 and have done a engine swap cuz previous owner ran nitrious and blew it up. it only had 16k miles but i wanna upgrade a lot in it so thats why i have asked so many questions
Old Oct 17, 2012 | 10:02 PM
Bad-A-SS's Avatar
It's fine man I'm here to help
Old Dec 21, 2012 | 09:02 AM
07ssBOOST's Avatar
Bad A, i pmd you
Old Dec 21, 2012 | 09:14 AM
Staged07SS's Avatar
Administrator
Administrator
**** 15 miles is cake!!
If I had an E85 station that close, I would run it no questions asked.
Hell, I drive 50 miles a few times a year for race gas.
Old Dec 21, 2012 | 01:31 PM
ThexGovenor's Avatar
Get a Header and 2.5 catback if you plan on dropping down to a 2.8 pulley or lower. If the E85 station is on the way do the E85 option. What are your power goals? The m62 is good to about 260 ish on 93 gas and a bit higher on E85. If you want higher than that start looking at a TVS or Turbo. If you decide you want to go those routes buy mods that will build into that or you will end up wasting a lot of money in the end. Ask me why I know..
Old Dec 21, 2012 | 05:00 PM
Pleass's Avatar
Yeah but your car is not dependent on race gas as like e-85
