stage kit
ur gas mileage will suffer tho most people report only getting like 24 to 26 highway when they calculate miles driven since last fill up vs amount of gas needed to fill back up. Some people still try to use the dic interface to give out there mpg but that **** was never accurate from stock so u can believe it wont be on a different fuel type. also u will need larger injectors for e85.
i want to run the stage 3 from zzp and get option b from ottp and run meth injection. i already have after market header and exhaust. Should i run a 2.7 pulley with 60 or 80 lb injectors? and should i have zzp tune it or find a tuner near by?
60s will be enough but if u ever plan to change over to e-85 then get 80s, if ur gonna be tuned for meth it needs to be a custom tune and not a can tune, so if zzp tunes it have them tune it in person or remote it NOT a can tune or find a local tuner that knows what they are doing.
Water/meth mix can be used lower ur iat2 temps and seal the rotors but having e85 ur already pretty much knock proof, iv seen a few guys run both but honestly i would t worry about it if u have e85 ur gonna be straight.
Sep 28, 2015 12:51 PM
