Stage kit or no stage kit
Old Oct 31, 2010 | 02:16 PM
Kwaila's Avatar
Just wondering if there is a way to check if i have a stock ss/sc or a stage kit has been installed? i bought it used so i don't know what the guy before me did to it...
any help is welcomed and one more thing, how much psi/kpa would a non-modded sc make vs a modded one?
Old Oct 31, 2010 | 03:33 PM
ULWizSS's Avatar
look at the pulley itself on the supercharger for numbers like 77.9mm or 2.9. How much you boosting as well might be a indicator a pulley been changed. Stage two is usually around 15psi while stock i believe is around 12.
I bought my car and was about to buy a gm stage kit until i found out it was already stage 2.
Old Oct 31, 2010 | 03:45 PM
Kwaila's Avatar
Thats exactly what i want to avoid
Old Oct 31, 2010 | 04:35 PM
ULWizSS's Avatar
Why would you want to avoid this. Saved me $1000 right out of the gate.
Old Oct 31, 2010 | 05:27 PM
Kwaila's Avatar
I meant i want to avoid buying a stage 2 kit only to find out I got it already
Old Oct 31, 2010 | 05:33 PM
JERMzSS's Avatar
yup just check the pulley or take a pic of it and post it for us. We will tell you what you got.
Old Oct 31, 2010 | 05:35 PM
SunburstSS's Avatar
Does the supercharger pulley have any bolts ? or it a round black pulley with one hole in the middle ? look at ur fuel injectors do they have a blue ring on top or green ?!
Old Oct 31, 2010 | 07:14 PM
Kwaila's Avatar
its the black one with a hole in the middle
https://www.cobaltss.net/gallery/fil...3/img_0244.jpg
Old Oct 31, 2010 | 07:15 PM
SunburstSS's Avatar
you are on stock pulley so no gm stage 2 how about injectors ?
Old Oct 31, 2010 | 08:36 PM
06G85's Avatar
Look underneath the fuel rail, if the injectors are GREEN you are stock, if they are black you are stage 1.
Old Nov 1, 2010 | 02:31 PM
Kwaila's Avatar
they are green...guess its stock
Old Nov 1, 2010 | 02:35 PM
SunburstSS's Avatar
so u officially have no stage kit !
Go get one now lol
Old Nov 1, 2010 | 02:50 PM
Kwaila's Avatar
i can just get stage two right? skip stage one since two has everything that stage one has? which website should i order from? zzperformance, crateenginedepot or just go to the dealer?
Old Nov 1, 2010 | 02:53 PM
Bluelightning's Avatar
Got Bewst?
Yes you can just go to a stage 2. If you have any warranty and want to keep it go with crateenginedepot. If not i suggest ZZP or OTTP. DON'T go to a dealer.
Old Nov 1, 2010 | 03:13 PM
Kwaila's Avatar
Would I need to get a cai and change the exhaust cuz they still stock as well
Old Nov 1, 2010 | 03:17 PM
SunburstSS's Avatar
Talking
no you don't need to, but depending on which stage kit you wanna go with and depending on your power goals an exhaust system upgrade might be neccessary or is recommended
Old Nov 1, 2010 | 05:33 PM
Kwaila's Avatar
Lets say i want to go with stage 2 n i want to avg 250hp... Wot wud you suggest? I ws tinkin more aling da lines of an injen intake, gmpp exhaust..
Old Nov 1, 2010 | 09:27 PM
Got Bewst?
Take a look at my mods...
Old Nov 2, 2010 | 12:33 AM
Kwaila's Avatar
Where would you recommend for installation in the Peg? Motion performance car tuning on king edward?
Old Nov 2, 2010 | 07:07 PM
Got Bewst?
You're stage 2? I can help you out if you want
Old Nov 3, 2010 | 01:50 AM
Kwaila's Avatar
Nope, still stock apparently. Itd b great if u cud. Inbox me your number and il get in touch
Old Nov 3, 2010 | 02:00 AM
ULWizSS's Avatar
I will sell you my GM Stage 2 parts dirt cheap. Taking them off the car this week and going 2.8 and 60's. Just a offer pm me if intersted.
Old Nov 3, 2010 | 02:15 AM
Phyrric's Avatar
assuming your getting GM stage 2 I'd pick the dealer over crate, crate is cheaper, but I just prefer knowing that if something ***** up its all on the dealer no "Oh well you bought it from blah blah" and so on
But if you have a good mechanic/performance guy you go to I would get the ZZP or OTTP one, cheaper and faster
But...
GM stage 2 is the slowest stage kit upgrade, but you'll still be grinning like a ************ when you first floor it
Old Nov 3, 2010 | 10:37 AM
ULWizSS's Avatar
But...
I did not find it slow at all since i was able to run better times than people with more mods and some with slicks even. With just a GM2 and CAI i was able to pull 13.6 runs at the track. Dont consider it super fast but definately not slow. Also put down 244/225 with GM2,CAI, 2.9 pulley.
Old Nov 3, 2010 | 10:50 AM
Staged07SS's Avatar
Administrator
Administrator
But...
No, really its not.
