Static in speakers after mods!!??
Old May 19, 2007 | 12:14 PM
Hopeless Regret's Avatar
I got an 06 with 16,000 miles and i just put in a 2.8, 60lbs, 1 step colder plugs. Now when ever I crank the radio up loud its really static and crackling and the rear speakers like pop. if I have it at a normal volume and give it gas the speakers get static again and then when I let off they get clear again. Its really weird. Is it something with the plugs maybe? Anyone seen this before? Thanks.
Old May 19, 2007 | 12:22 PM
beercan's Avatar
did you get the coil packs put back tightly on the plugs? .. you could have some voltage shorting to ground and that WILL run back through your headunit and speakers .. check all your connections for everything you changed and make sure they are snug and you didnt break any of the insulation on any of the wires
Old May 19, 2007 | 12:47 PM
Mikey851's Avatar
Did you get a Tag kit? I forget which company did this, but someone told me of a part number (Spark plugs) they got with their kit and I found the plugs on NGKs website. They turned out to be resistorless race plugs which can cause alot of RFI. What part number do you have?
Old May 19, 2007 | 01:40 PM
BlackSS/SC's Avatar
I had static in the speakers with the plug that TAG uses. The NGK non-resistor ones.
Old May 19, 2007 | 01:41 PM
Toronto SS's Avatar
me too, brk7e's cleared everything up
Old May 19, 2007 | 03:13 PM
Mikey851's Avatar
Yep, change to the brk7e's and you should be good. It's extremely dumb that Tag puts resistorless plugs in a street kit.
Old May 19, 2007 | 03:17 PM
Yea, I got the TAG kit and I bet everyone of you guys are right because Ive went through the whole motor and tight every ground and check every wire. I love my music so its really getting to me!!! Any of you guys got the part number for the plugs that will fix it?
Old May 19, 2007 | 03:20 PM
Toronto SS's Avatar
NGK BKR7E
Old May 19, 2007 | 05:11 PM
RG4's Avatar
RG4
Yea same here, get the bkr7e plugs it will make things right
Old May 20, 2007 | 12:43 PM
What gap should I use?
Old May 20, 2007 | 12:48 PM
Toronto SS's Avatar
.35 will work
bigdeertz
Nov 17, 2016 09:41 AM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
