Still burning coolant!
Old Jun 26, 2012 | 09:45 PM
timhebert's Avatar
How many hr job is it to change hg
Old Jun 27, 2012 | 11:45 PM
Tjolley's Avatar
i have pulled the head a few times on my lsj..it took me about 5 hrs with beer. gettin it off is easy. putting it back on is the pain in the ass cuz u have to pull the front cover to time the cams and all that good stuff.
Old Jun 28, 2012 | 09:35 AM
mrbelvedere's Avatar
you dont have to pull the front cover there is a tdc mark on the front cover for timing the engine
Old Jun 28, 2012 | 10:43 AM
SaberD's Avatar
while not necessary, I would suggest removing the front cover to inspect the guides, as they have been known to break.
Old Jun 28, 2012 | 11:36 PM
I8URVET's Avatar
Have you done a dual pass endplate and swapped the Lam cores? another culperate for loosing coolant is the O rings on the cores, if its small enough leak it wont smoke.
Old Jun 29, 2012 | 12:03 AM
Unique Crysis's Avatar
might as well check the thermostat and the thermostat housing see if any of the seals are bad
Old Jun 29, 2012 | 02:51 AM
timhebert's Avatar
I've checked all hoses and that, can't find where it's going. None in the oil and no white smoke. Is there anyway to check if hg is leaking?
Old Jun 29, 2012 | 04:51 AM
Hodz's Avatar
Its a possibility that its the o-rings for the laminova cores in the intake manifold. But that can be pricey since GM sells them for like 16 doll hairs a piece and there are 8 of em. Head gasket would be cheaper and I do have a brand new gm one for sale
Old Jun 30, 2012 | 11:34 AM
Tjolley's Avatar
i have the head off my lsj now and ill have the new hg on thursday...ill do a quick write up on changing it for u all i also have the gm factory service manuals..
parts list
arp head studs (u have to replace the stock head bolts wen u take the head off cuz they have a torque to yeld spec. meaning wen they get torqued down from factory they stretch so if u reuse them u will end up breaking them or u will never get them tight enough and end up with the same problem again) the arp head studs r reusable and they give the head higher clamping pressure to the block.
u will need a head gasket (if u go a mls style u will need to coper spray it)
new intake manifold gasket
new exhaust manifold gasket
ill do the rest later but this should give u a good idea.
Old Jul 10, 2012 | 10:53 AM
06SilverG85's Avatar
+1 on the head gasket minor leak into the combustion chamber, lived it for 5 years, low coolant every 20k miles.
Old Jul 15, 2012 | 10:51 AM
  #36
Tjolley's Avatar
Well finaly got my parts from ottp not sure y it took so long but...the car is back on the road and no low coolant problems so far..
It looks like the coating on the hg came off around number 1.
As far as silverg85 i think ur problem is the block casting problem. With as slow of a leak as u have.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
