Stock Boost? why is my gauge off?
Old Dec 19, 2007 | 01:32 AM
19transam81's Avatar
ok, i have had my 06 cobalt ss/sc for about a month now. i have been on this board for about 2 weeks now. i am thinking about many upgrades. i have seen that the CA stage 3 gives you 17-18 psi. i was pumped when i saw that because my gauge says i am getting 2.5-3 psi. i saw on this board that 12.5 is stock. why am i only seeing 2.5-3? is it the gauge or is the car only getting that much boost.
Old Dec 19, 2007 | 01:47 AM
c0ld29's Avatar
your gauge must be off... unless you never stomp it. You won't be at 12 psi always, thats max (depending on elevation)
by the way... you have a 2.0 LSJ supercharged, not the 2.0 LNF turbo lol wrong section
also I would suggest a lot of research on different things before just jumping in and buying an aftermarket staged kit.
Old Dec 19, 2007 | 01:53 AM
well, i am in Michigan at about 1000 ft above sea level. I do get on it alot... but i never see a reading above 3.
Old Dec 19, 2007 | 01:56 AM
c0ld29's Avatar
well normally no matter the elevation you wont be that much off of the stock readings. Your gauge is probably off unless you feel like your car is pretty sluggish. Bring it into the dealer and have them check it out. The gauge is probably just being stupid like mine was (stopped reading all together lol)
well nvm if you only had the car a month you wouldn't know if it was sluggish or not lol....
bring it to the dealer anyway.
Also... does it slowly climb to 3psi... or does it shoot up to it then kind of freeze?
Old Dec 19, 2007 | 02:04 AM
REIGN SS's Avatar
Original Hayden Fanatic
moved to LSJ section, you do not have an LNF cobalt
Old Dec 19, 2007 | 02:05 AM
L.P.'s Avatar
Haha give him a break he's a noob.
Old Dec 19, 2007 | 02:06 AM
lsjwannabe's Avatar
what gear do you see the psi in? probably a bad gauge check with the dealer
REIGN SS's Avatar
i was just stating that i moved it, sometimes ppl get confused when there thread is moved & no one says why...
c0ld29's Avatar
Hey I stated that in my first post lol. I got your back Reign!
Old Dec 19, 2007 | 02:13 AM
it climbs fast to 3. the car has *****, i mean it gets up and gos when it hooks up. it only has 20,000 miles on it. but in first gear i hardly see 1 psi.
Old Dec 19, 2007 | 02:15 AM
lsjwannabe's Avatar
its first gear its to short to see boost lol well at least for me. Put it in third and redline it and see what you pull
Old Dec 19, 2007 | 02:28 AM
i have a g-tech and i have gone down the road with it. the g-tech said i crossed the line at 102mph and i never saw a reading past 3.... so i am thinking it is the gauge. ill go to the dealer tomorrow then.
Old Jan 12, 2008 | 07:32 PM
True, it was the gauge now i have seen up to 13 psi.
Old Jan 12, 2008 | 07:44 PM
streetrcer909's Avatar
ya im stock except for a cai and im hitting 13 psi right now im right above sea level so idk i use to only hit 12.5 so its not that much of a difference just figured id throw in my 2 cents haha
Old Jan 12, 2008 | 10:45 PM
zipo1200's Avatar
well mine is way off. i am hitting over 140 kpa, 21+ psi. ahaha. and thats at like 5,000rpm. when it goes over 140kpa the engines starts backing off. really crazy. it goes to the dealer on friday to find out what the hell is going on
oh and btw its stock
Old Jan 12, 2008 | 10:55 PM
lsjwannabe's Avatar
bad gauge or clooged cat
Old Jan 12, 2008 | 11:15 PM
jimbos'ss's Avatar
overboosting, probably clogged cat like previously stated
DarrenGC
Dec 24, 2021 01:55 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
