Stock injectors safe for 7k?
Old Aug 13, 2006 | 09:06 AM
zinner's Avatar
Moderator Alumni
These are mine thoughts on the AFR requirements.
Dangerous >= 13
Pig Rich <= 10.5
My ideal is:
12.5 boost only
11.5 nitrous and boost
Old Aug 13, 2006 | 10:34 PM
StinkBOMB's Avatar
Just out of curiosity if 14.1 or 14.7 is Stoich, then why is 13 dangerous? I'm having to stay out of the throttle until Doc gets down here and we can put in my 42 lbers and reflash.
Old Aug 13, 2006 | 10:48 PM
chipmonk212121's Avatar
Originally Posted by Bad06SS
If you have HP Tuners, you've got a scanner. Try it, scan, and if it's not safe, change it back. Let us know how it worked out.
hmm thats kinda what I was thinking...
Old Aug 13, 2006 | 11:02 PM
06black's Avatar
Originally Posted by denny
If he is running a stock pulley without the boost bypass mod he isn't making more boost at higher RPM. 500 more RPM with stock pulley is not even close to putting him in dangerous territory. Our cars stock, run PIG Rich.
you dare argue with the WOP?
bad idea...he knows more then you or me and dam neer any body else on here(if not all) in regards to our cars.
now to answer the original question NO i dont think its a good idea.
yea our cars run rich for MOST the RPM band but its possible to get our injecters in to the 80-90% duty cycle range...our injecters go static around the the 94% mark.
after all GM would not of included biger injecters with stage 1 kit IF our stockers could handle the higher revs.
also another 500-550 engine RPMis at least 1000 or so more blower RPM so yea your boost numbers will increase as well.
thus the need for more fuel also goes up...and i cant see the stock injecters beable to handle any of this.
the boost solinoid bleeds at 16.6lbs if i remember correctly(correct me if i'm wrong)
I'm guilty of runing my injecters WAYYY past the static cut off many times!
i've seen my HP logs go into 115-118% when i had my 43's and 2.7 plus one HELL of a tune.
take this as you want but i DO NOT recomend doing this...at least for any sort of a prolonged time.
Old Aug 14, 2006 | 01:39 AM
Cobalt_Supercharged's Avatar
The supercharger will push more CFM but it is still the same S/C to Crank ratio, so it will not increase the boost, it will just provide the full 12 psi throught the extra 500 rpm.
At WOT you want to run ~11.5-12.5 AFR ratio for a FI engine to get maximum power and not over heat the engine. The leaner you get, the hotter the engine will run. Stoich is theoretically the most complete burn, but not the safest or most powerful.
Old Aug 14, 2006 | 05:09 AM
SilverSS/SC's Avatar
That is unsafe at full throttle . 14.7 is a desired cruise and idle a/f .
Gm included the bigger injectors , because being an OEM and having to deal with warranty issues ect ect , they have to be completely OVERKILL safe on the tune .
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
