stock lsj 15psi?
Old Apr 6, 2010 | 02:09 PM
MP Cobalt's Avatar
Originally Posted by Frew
why do people gut there cats? People have dyno'd with gutted cats and the turbulence generate has been shown to lose hp. The only reason I could see if someone didnt wanna deal with COT.
If i want catless i buy a catless dp, or what not.
Old Apr 6, 2010 | 02:12 PM
Frew's Avatar
exactly, theres no turbulence is a straight piece of pipe
Old Apr 6, 2010 | 02:14 PM
MP Cobalt's Avatar
hah way off topic but im picking up a tranny this week. 50k miles and lsd says it shifts so fine i guess i;ll see
Old Apr 6, 2010 | 02:19 PM
Frew's Avatar
sweet man, you get a chance to go see fran about a toon?/end thread jack
Old Apr 6, 2010 | 02:24 PM
MP Cobalt's Avatar
haha naw last i talked to him was a while ago. idk if his camaro is up n running yet. lol
Old Apr 6, 2010 | 02:40 PM
jonathan923's Avatar
so itll be better in the end if i just get a catless down pipe or just put a straight pipe where my "cat" is huh?
Old Apr 6, 2010 | 02:42 PM
chris88z24's Avatar
I boost like 12psi with stage 3. lol
Old Apr 6, 2010 | 02:50 PM
MP Cobalt's Avatar
yeah the best bet would be to buy a catless dp if you want to stay catless. That's the way I would do it. I always say do it the right way or don't even bother wasting your time doing it the cheap way.
haha thats beat. i was hitting 14 psi on stage 2
Old Apr 6, 2010 | 03:34 PM
Durtyss's Avatar
Gm stage kits still regulate 12.5 psi after 6500. So I'm not sure how u guys are hitting higher then 12.5 before 6500. You must have clogged cat.
Old Apr 6, 2010 | 03:40 PM
MP Cobalt's Avatar
idk i know i was hitting 14 on stage 2 when i had it. but i had exhaust and stuff.
Old Apr 6, 2010 | 04:48 PM
  #36
mrbelvedere's Avatar
well igot a 2.8 and im showing 21lbs and im catless my guage is bad and so is your probably
Old Apr 6, 2010 | 06:13 PM
  #37
Frew's Avatar
for sure, everything in making power is better flow and more fuel for our cars. If you know where the restrictions in our engines are you can make some decent power and not waste your money on things that dont need upgraded
Old Apr 7, 2010 | 01:04 PM
  #38
Chevycobaltss3's Avatar
Our gauges are known for there 1-2 lbs off from wut we are actually pushing. But I say cloggggg lol
Old Apr 8, 2010 | 12:22 AM
  #39
SunburstSS's Avatar
15 psi on stock injectors.....hmmm thats sounds really nice guys if he was literally getting this boost wouldnt his engine go kaboom from leaning out lol..most likey a bad ***** cat..i was running 19 psi on a stage two but apparently my cat was bad...
Old Apr 8, 2010 | 12:29 AM
  #40
EXsoccer1921's Avatar
Originally Posted by Backdrift
Running a car up hill, or with extra weight in the car will cause your car to generate more boost. You're making the car work harder, because by adding one of the two scenarios above, the car will understand it needs to generate more power to pull the weight.
uhm....no.
check your boost bypass valve. it may not be opening all the way. mine had that problem. thought i had it fixed. but then it started opening too early.
Old Apr 8, 2010 | 07:59 AM
  #41
our injectoers can copinsate for a short time, but hen itll go lean and then kuboom, i still say its clogged, because even if the bypass valve wasstuck yous till would not get that much boost because it dont open till around 6k to be safe, so if it builds up while in rps then you have a clogg
Old Apr 8, 2010 | 10:54 AM
  #42
am trying to find a cat less down pipe. just trying to decide which is better either zzp or ottp. any advise? this way i can just get rid of my stock down pipe. lmk thanks!
Old Apr 8, 2010 | 11:02 AM
  #43
I have a catless downpipe from zzp, and i have had no problem with it. Its held up ggod, there older d.ps are junk tho. so watch out. i havent heard of ottps yet so who knows.
Old Apr 8, 2010 | 01:50 PM
  #44
rnjmur's Avatar
Maybe it is like this in a newer stage tune, but my stage 2 tune had full boost at all times.
The car does not generate more boost when you put it under a load.
Just because the PSI measured at the manifold is higher does not mean that your are moving more air. If there is a clog then the back pressure is raising the pressure in the manifold, it does not mean that the car is running lean, in fact it is probably running rich if anything.
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
Sep 27, 2015 08:53 PM
