Thermostat
Old Apr 7, 2010 | 05:32 PM
BallinBlackbaltSS's Avatar
Thermostat
So does any one know where the termostat is on the 2.0 LSJ i need to replace it and i cant find it.. thanks
Old Apr 8, 2010 | 12:28 AM
Dainslaif's Avatar
It's behind the engine and a massive PITA to get at. I was gonna replace my thermostat as well but decided against it once I figured out where it actually was, haha.
Old Apr 8, 2010 | 01:50 AM
shadowfaxss's Avatar
Easiest way I've found to do this is to remove the cam sensor and housing (make sure everything is timed and aligned). All you need to do is drain some of the coolant and remove the thermostat housing bolts; lift up the housing and replace.
Old Apr 8, 2010 | 12:39 PM
trey ss's Avatar
which termostat lol
Old Apr 8, 2010 | 01:07 PM
Frew's Avatar
I have seen in the lsj build guide that they run a modified thermostat in there final motor build, anyone have any ideas as to why? I am aware of big V8's running hotter thermostats for power reason, was the lsj a colder or hotter?
Old Apr 8, 2010 | 01:18 PM
rnjmur's Avatar
No need to run a different thermostat unless it is strickly a race car.
With a highly modified race car you sometimes have to run a colder/hotter thermostat to attain the proper combustion chamber tempuratures.
Old Apr 8, 2010 | 01:21 PM
Frew's Avatar
ya my buddy runs a hotter thermo on his 2010 tvs'd camaro ss
Old Apr 8, 2010 | 02:16 PM
coolant thermostat, i heard its like right nex to fuse box to the left and under. is this true?
Old Apr 8, 2010 | 04:47 PM
rnjmur's Avatar
The thermostat basically sits right in front of the water pump. It is in the coolant line running on the back side of the motor under the exhaust manifold on the passenger side.
Old Apr 8, 2010 | 05:11 PM
The thermostat is next to the fuse box and the exhaust manifold; backside of the engine.
medic710
Sep 6, 2015 08:53 PM
Dmoney8187
Feb 20, 2012 09:11 PM
Karlen89
Jan 1, 2009 07:08 PM
fivepointohman
Jun 15, 2007 05:01 PM
Modbug
Aug 16, 2005 09:20 PM
