gms3 pully
Old Apr 8, 2010 | 11:20 AM
edmbaltss's Avatar
gms3 pully
what is the size of a gm stage 3 pully
Old Apr 8, 2010 | 11:24 AM
Staged07SS's Avatar
Administrator
Administrator
76mm / 2.992"
Old Apr 8, 2010 | 11:44 AM
Backdrift's Avatar
Correction;
2.99212598 inches
But you typically would just round that to 3.
Accurate ******* is accurate.
Old Apr 8, 2010 | 11:48 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by Backdrift
Correction;
2.99212598 inches
Anything after the 3rd decimal place is "usually" irrelevant to accuracy, sooo my number is correct I'm an engineer, I can't help being **** with numbers. It's much easier to just say 76mm and avoid the is it a 2.99" or is it a 3.00" pulley .... haha
Old Apr 8, 2010 | 11:51 AM
Backdrift's Avatar
That depends on what you're machining that makes it irrelevant. Could be extremely relevant in this case.
But lets not get off topic.
Stage 3 FTW.
Old Apr 8, 2010 | 11:53 AM
Staged07SS's Avatar
Administrator
Administrator
Stage 3 FTW.
Agreed sir
Old Apr 8, 2010 | 12:37 PM
trey ss's Avatar
wherer can u find GM stg 3?
Old Apr 8, 2010 | 12:45 PM
Staged07SS's Avatar
Administrator
Administrator
http://www.crateenginedepot.com/stor...P1689C196.aspx
Old Apr 8, 2010 | 03:03 PM
dufcobalt's Avatar
Is there a big difference between 2.9" and gms3 pulley of power?
or is the same thing?
Old Apr 8, 2010 | 03:17 PM
northvibe's Avatar
that would depend on your parts and tune. if you are on stage 3 but then wen to a 2.9" pulley then yes more power/boost. So you need to elaborate on your question.
Old Apr 8, 2010 | 03:22 PM
Backdrift's Avatar
What he said.
Keep in mind, you'd be running 42s# injectors. Which although is safe IF YOU GET A GOOD TUNE, it is not recommended. Guy who runs Slick Motorsports around here told me that if you were to go below 3in pulley, you need to run 60# injectors, with a good tune.
Old Apr 8, 2010 | 03:36 PM
Staged07SS's Avatar
Administrator
Administrator
What he said.
This is correct especially if you are running the GM Stage 3 tune, because it runs fairly lean (11.4 AFR). It's best to stick with the 76mm GM Stage pulley if you are going to run the GM Stage 3 PCM.
Old Apr 8, 2010 | 03:38 PM
northvibe's Avatar
well and if you drop below that Id probably recommend the option b, and a bigger/2nd heat exchanger.
Old Apr 8, 2010 | 03:42 PM
Staged07SS's Avatar
Administrator
Administrator
i agree .... opt b has done wonders on my setup. The constant bleeding of the intercooler system, and slightly increased coolant capcity has really kept my IAT2's low
Old Apr 8, 2010 | 04:00 PM
northvibe's Avatar
I keep bugging rallyracer to get a gm stage 3 or option b. I also keep my eyes open for a cheap SC/SS to build up. Nothing like that whine
Old Apr 8, 2010 | 04:20 PM
Staged07SS's Avatar
Administrator
Administrator
I hear ya man .... It puts the same smile on face as it did the first day I drove my car off the dealership lot
Old Apr 8, 2010 | 04:46 PM
Pyros777's Avatar
Time for the obligatory Trifecta S3 mention:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/gm-stage-3-trifecta-204466/
Trifecta Performance can tune the GM S3 calibration now, and is hard at work at unlocking the A/C. See above link for details.
Old Apr 8, 2010 | 06:11 PM
Nighthawk243's Avatar
Would make a large number of people less reluctant to upgrade to GMS3.
poppagun
Jun 27, 2006 07:18 AM
Badmunky
Apr 24, 2006 02:01 AM
Blue04RedLine
Jan 10, 2006 11:37 AM
1MEANSS
Dec 19, 2005 01:02 AM
Darksun
Nov 2, 2005 09:41 AM
