strange boost issues
Old Nov 18, 2005 | 11:08 PM
selfinfliction's Avatar
so tonight i'm playing around a little and notice that in second gear i am pulling around 14 psi which i guessed was because of the nice cold weather or whatever, but when i hit third gear and max it out, it only goes to 12-12.5 before you see the needle bouncing around from the bypass valve actually opening.
has anyone seen this issue before? it's like my system isn't limiting boost in second, but is in third. i'm not sure about the other gears cause i didn't want to be driving that fast tonight.
i'm not even sure what would cause this, unless it's just a fault in the pcm
Old Nov 18, 2005 | 11:11 PM
phxSS's Avatar
****, I'm only getting 11 psi max outta my car. And you're complaining of "only" 12.5? LOL I could only dream of that.
Old Nov 18, 2005 | 11:17 PM
OniMirage's Avatar
if its bouncing around I would check your lines if I was you ... the first ss i test drove had a similar issue with the bouncing needle and it turned out to be a disconnected line
Old Nov 18, 2005 | 11:21 PM
zinner's Avatar
Moderator Alumni
I get that as well unless I have my foot on the floor and then my boost bypass is disabled (thanx maven).
Old Nov 18, 2005 | 11:23 PM
Psycho's Avatar
I never seen anything like that The one I test drove was awesome I burned 1/2 a tank It was awesome but red.It was so awesome I ordered a black one and Its been flawless 12.5 to 13.5 depending on temp..Onimirage might be a line,does the car seem ok ?
Psycho's Avatar
Could just be the guage!!
Old Nov 18, 2005 | 11:26 PM
SSpartan's Avatar
boost
ive only had 10 lbs of boost.
but the guages arent exact from my understanding
Old Nov 18, 2005 | 11:37 PM
it's not bouncing much at all, you can see it twitching around the levels where the bypass should be kicking in and letting the boost out. maybe it's got something to do with the new exhaust i put on... but it shouldn't be doing it in only one gear though
Old Nov 19, 2005 | 12:14 AM
VaMP's Avatar
Considering this is a digital gauge controlled by a PCM, you can't really trust it. If you were getting this on a mechanical that would be another thing...
Old Nov 19, 2005 | 12:49 AM
06black's Avatar
HA with a lil work....very little i'm at 15....in a week i'll be a 16....than the stg 2 reflash and the there no limt to whats next
Old Nov 19, 2005 | 04:57 AM
undrgrndcobalt's Avatar
12.5 here bone stock... no boost bypass mod
Old Nov 19, 2005 | 08:22 AM
i guess it has to be this or something. maybe i'll temporarily wire in a mecahnical gauge today and drive around with it to see if it's actually getting that
Old Nov 19, 2005 | 02:49 PM
OniMirage's Avatar
yeah noone has really mentioned any speculation on the increase in boost with the stage upgrades just that there will be one .... hmm maybe I should go find those other threads and re-read them again
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
