Strange exhaust leak or is it?
Old Jun 10, 2008 | 03:02 PM
methodman2424's Avatar
Well i installed my 2.9 pulley on with nor problems about 800 miles ago and now I am getting what seems to be an exhaust leak that is gettung worse by the day. I took it to 2 muffles shops and they can't find the hole anywhere. They even covered up the tail pipe and evrything with no results. 1 guy said its the supercharger making the sound but I sure hope it isn't. I personally put it on the lift at work(I paint cars and do bodywork) and me and the mechanics are clueless. You hear nothing at normal pedal but as soon as you hit boost and especially when you punch it...its a horrible sound. Any way these can be the supercharger?
Old Jun 10, 2008 | 03:08 PM
krazycobalt's Avatar
yeh dude take it down to GM and let them take a look but if i was you i would put the stock pully back on
Old Jun 10, 2008 | 03:10 PM
Well I have an apointment tomorrow at 8am so no time to put the stock pulley on and I doubt they will notice it they are reatrded at this dealership. I mean I have no prob buying a header but I am just praying thats what it is.
Old Jun 10, 2008 | 03:13 PM
yeh well you could have a **** up gasket or something of the sort but here is a little trick. If you have a welding rod without the **** on it or something like that put one end on the supercharger and your tumb on the other end and the put ur thumb in ur ear. You may look like a retard but you can hear the blades, the air and everything. GEt some one to rev it up while you listen. Just see if the sound is from there.
Old Jun 10, 2008 | 03:14 PM
And what if it is
Old Jun 10, 2008 | 03:16 PM
Well listen for anything out of the normal, like a scraping or anything and if it is. I hope that you have warranty.......... cause there is a problem with ur blades
Old Jun 10, 2008 | 03:17 PM
RoAdsZ24's Avatar
Same problem with mine when it was stock. Nobody could tell me where the noise was coming from.
Turned out to be the gasket between the header and downpipe.....warranty fix
Old Jun 10, 2008 | 03:21 PM
Well thats where the one place says it might be coming from and I thought it was that or a hole in the maifold under the heat shield. Was yours load as hell when you stomped on it?
Old Jun 16, 2008 | 02:27 PM
RoAdsZ24's Avatar
Yeah, the higher the boost, the louder it was. Very obvious that it was a leak.
Old Jun 16, 2008 | 02:35 PM
SS33's Avatar
We have a cast manifold stock, I HIGHLY HIGHLY doubt there could be a hole in the manifold. I would think that a gasket, the flexpipe, or even your cat could be the culprit here.
Just my .02, but There is literally no way in hell that you have a hole in the manifold itself
Old Jun 17, 2008 | 12:07 AM
restonSS's Avatar
+1 ^
Old Jun 17, 2008 | 12:36 AM
Sythen1678's Avatar
Thank The Lord!! I have been having the same problem when i hit boost! I hit a huge bump and i feel like it shifted something with the exhaust loose, ill fix all my gaskets and see if it fixes it, i really hope its not the supercharger!
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
