Strange noise from engine
Old Aug 20, 2009 | 02:07 PM
Rydis's Avatar
I noticed it a while ago, but I haven't been able to figure this one out. I have a strange sound that is comming from the center or near right of the engine. Kind of sounds like a piece of paper in a fan going "tack tack tack". It doesn't come and go, it a non stop type sound. I can't really tell exactly whats causing it, but I can't find any lose connections or screws, or anything that might cause it. Someone said they thought it was comming from bottom of the TB, but im not 100% sure.
Any ideas?
Old Aug 20, 2009 | 02:10 PM
light'bolt's Avatar
sorry to ask but how's your fluid level??
Old Aug 20, 2009 | 02:12 PM
Rydis's Avatar
Transmission fluid? I am not sure, I never checked it.
No need to be sorry, im not the most mechanical, im still learning as I go.
Old Aug 20, 2009 | 02:20 PM
northvibe's Avatar
you sure its not the supercharger? have someone rev it to see if the noise happens quicker.
Old Aug 20, 2009 | 02:21 PM
Rydis's Avatar
Ive tried that, but its not a very loud sound. The engine being rev drowns it out.
Old Aug 20, 2009 | 02:22 PM
HeCTiC 6ft dp's Avatar
Does the noise always stay at the same rate or does it change with throttle?
Old Aug 20, 2009 | 02:30 PM
Rydis's Avatar
I sounds like the noise stays at a constant rate. It doesn't come and go, its always there and has a certain pattern. It doesn't get lounder on its own, or skip around, its just a contant, tack tack tack tack.
Very similar to a playing card in a spoke, though the sound is different.
I will try again to see if I can hear anything when throttle is given.
Old Aug 20, 2009 | 03:00 PM
Could it actually be something caught in the radiator fan? A tree leaf? A loose hose? Did you check it at all?
Old Aug 20, 2009 | 03:30 PM
Rydis's Avatar
Yeah, I couldn't find anything.
Old Aug 20, 2009 | 03:36 PM
Karlen89's Avatar
Flex pipe on your downpipe might be leaking. Mine made a noticeable noise until the flex actually cracked completely.
Old Aug 20, 2009 | 03:53 PM
northvibe's Avatar
valves ticking? fuel rail? SC rotors ticking? On some SC's over time I've heard people say they can rub on eachother.
Old Aug 20, 2009 | 04:56 PM
Rydis's Avatar
I didn't notice any leaks under the car. I just went and checked again, and I was wrong, its not a constant thing, it is rather erradic. Its also something that started a few months ago.
When I had the SC out a while ago, I had had turned it and I didn't really notice anything, but I obviously can't turn it was quick as the engine.
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
