stripped bolt
Old Jan 10, 2009 | 01:10 PM
venum_us_2002's Avatar
stripped bolt
So i was taking off my megan catback and the bolts connecting to the Downpipe were fine to get off and than i started working on the section by the axel and i cant get one of the bolts off, i think i stripped it. What should i do?
Old Jan 10, 2009 | 01:12 PM
wrathofgod's Avatar
buy that gatorgrip socket, vicegrips, or just cut it hahaha
Old Jan 10, 2009 | 01:13 PM
shutzero's Avatar
cut it off with a grinder, or drill it out
Old Jan 10, 2009 | 01:14 PM
could i cut it off with a dremel?
Old Jan 10, 2009 | 04:55 PM
HunterKiller89's Avatar
depending on what the bolt is made of...probably. dremels are strong enough to cut the subframe thoguh.....theyre tough little discs
Old Jan 10, 2009 | 08:03 PM
Dainslaif's Avatar
Bolts are steel, a dremel can cut through it but it might take a few discs. If you have a cutting torch that'd be way easier.
Old Jan 10, 2009 | 08:12 PM
Tank07's Avatar
drill it out first........see what you get.......if not cut and drill......
Old Jan 11, 2009 | 02:32 AM
tdipowered's Avatar
saw awl!!!!!!!!
Old Jan 11, 2009 | 02:35 AM
Jbernal4368's Avatar
Originally Posted by tdipowered
saw awl!!!!!!!!
you mean sawzall???
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
