stripped bolt head
I would suggest drilling where its stripped.. When you get to the shaft. The bolt head will come off and allow you to remove the supercharger.. Then remove the shaft of the bolt with vise grips... after you remove the supercharger that is.
because i'm a retard and don't read posts all the way sorry.. i thought you were doing something with the actual supercharger.. not the pulley.. so listen to these other guys and get the easy out set.. or you could still drill it out and use a punch to tap out the bolt if you don't wanna spend any money.
Sep 28, 2015 12:51 PM
