stroker 2.4 lsj
Old Jun 23, 2012 | 09:03 AM
Tjolley's Avatar
stroker 2.4 lsj
well I am working on building a stroker lsj.. I know that z z performance sell them.. I would prefer to build my own.. has anyone done this yet..
Old Jun 23, 2012 | 09:21 AM
MP Cobalt's Avatar
yes unless you know what you need to do properly to stroke it dont do it yourself. ZZP you might pay but you'll wish you had
Old Jun 23, 2012 | 09:41 AM
Tjolley's Avatar
So did you build it yourSelf... what kind of power did you see...
Old Jun 23, 2012 | 11:06 AM
MP Cobalt's Avatar
My bad I didn't do it, I was just saying. I accidentally typed yes
Old Jun 23, 2012 | 11:22 AM
Tjolley's Avatar
Oh ok i know that the le5 crank is cast iron and the lsj is forged...big difference in strength there..i build engines for a living..i have access to all the tooling to make it work i was wondering if any one has done it out side of zzp..i just can't justify spending that much money on a engine Wen i could do it for 1/2 the cost of less..i can
get a brand new le5 crank for 320 shipped to my front door.
I have another thought to combine the zzp 2.1 lsj block with the 2.4 crank...should come out to be a 2.5 lsj. Any thoughts about that
Old Jun 23, 2012 | 08:24 PM
MP Cobalt's Avatar
I believe all the ecotec cranks are the same? I can be wrong but that's what I was told its all rod length and such
Old Jun 24, 2012 | 01:50 AM
Sharkey's Avatar
lsj-86mm bore, 86mm stroke
l61-86mm bore, 94.6mm stroke
le5-88mm bore, 98mm stroke
le5 crank in lsj or l61 gives a 2.3l, lsj or l61 crank in le5 block is 2.1l. those are the only combos you can build with stock blocks/cranks. you cant get a 2.5l, at least not without boring the block or a custom crank.
Old Jun 24, 2012 | 03:36 AM
Tjolley's Avatar
Hmm ok thanks for the info..makes sence..wat about a 90mm bore in a lsj block and the le5 crank..i can have JE forge the pistons and have darton make the sleeves and i can bore the block for larger sleeves..i wonder wat it would take to get a head gasket made?
Old Jun 24, 2012 | 10:35 AM
freakta's Avatar
my goal is a 2.5 as well
Old Jun 24, 2012 | 12:52 PM
Tjolley's Avatar
I just don't want to snap a the cast le5 crank. That's y Im asking. Cuz my plan is a s259 turbo step up after that.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
