Stronger roll pin replacement
i kno a couple people have done modifications to the roll pin to make it not break as often. what have you guys done
mine broke at 24000 miles, got it fixed and it broke again within 300 miles
on the diff in the trans right?? i think the should be a seperate chamber or a half wall or something sothe ring gear and spiders wont sling the oil out so quick... trapit but leave a small hole in the bottom of the wall but thats my 02.C
I got a heavy duty roll pin from my buddy who works for a C balt race team and I hacked the rediculous weight off...and now im problem free. He told me the issue is that on some cars the hole wasnt drilled properly(not sure how it only happens to some) so as you put a new pin in its actually bending it so its weakened off the bat.
Something must be wrong with your car.
When I first had my SS/SC the shifter needed adjustment so I hit the stop several times trying to get into third. And I hit that bastard hard too, I nver had one issue with pins.
Anyone come up with more information on a fix for this? Mine was sliding out today and we tapped it back in, but it just came right back out. What size have people been drilling this out to and are you going through the wheel well to drill or taking out the fuse box and coming from above?
