Stumbled across a possible 2"primary LSJ Header?..
Old Nov 21, 2009 | 11:24 AM
  #51
spitefulxcheerio's Avatar
so now that the bickering is done, can we determine if this header is even worth it?
What do you guys think would produce the most power? a 1.75" header with a full 3" exhaust? Or what?
Old Nov 21, 2009 | 11:26 AM
  #52
ilovecars's Avatar
Property of RDFabs
Old Nov 21, 2009 | 11:28 AM
  #53
JohnnySasakiMGS's Avatar
Originally Posted by ilovecars
Property of RDFabs
Damn right!
Old Nov 21, 2009 | 11:58 AM
  #54
ilovecars's Avatar
Originally Posted by JohnnySasakiMGS
Damn right!
haha yea cody is muh buddy.
Old Nov 21, 2009 | 12:09 PM
  #55
Edubs's Avatar
lulz...
...yet another RD Fabs thread sidetracked to the nth degree!
Old Nov 21, 2009 | 01:44 PM
  #56
Tinkles's Avatar
This header was fabbed up on a J-body L61, test fitted in Edubs 06 SS(before the final welding), and finally installed in a 03 Cav with Edubs old M62 set-up. There is no noticeable drop in low rpm torque or hp, but a nice gain up top. It has 2" O.D. primaries(about 1 7/8" I.D.) and a 3" collector, full 304 Stainless steel(including the LSJ header flange).
It is also mated to a full 3" exhaust and it was built with the anticipation of a TVS build on the cavalier.
They are available right now for purchase. You just have to get in touch with a sales rep from RD Fabs.
Old Nov 21, 2009 | 04:31 PM
  #57
HunterKiller89's Avatar
depends how much power you're pushing. it would be ideal for something like a 400-500whp cobalt, but if you're in the 200-300whp range, 1.75" primaries is plenty.
Old Nov 21, 2009 | 04:51 PM
  #58
ralliartist's Avatar
1 7/8" inner diameter, good to know, that header doesn't seem so rediculous anymore. hmmm, I need a new header to fit my freshly re-ported head.
Old Nov 21, 2009 | 05:30 PM
  #59
ff_drift_lol's Avatar
that collector is beast
Old Nov 21, 2009 | 06:42 PM
  #60
Tinkles's Avatar
Stock L61 collector vs 3" collector
Stock L61 ports vs SS LSJ flange
Inside of the collector
Installed
J-body down tube(minus the mangaflow)
Old Nov 21, 2009 | 06:52 PM
  #61
awesome. I love that it's v-band too! some quality work right there.
Old Nov 21, 2009 | 07:14 PM
  #62
Maven's Avatar
What did you think it would be inside? of course its smaller than 2", when was the last time a header got sold by its primary ID????
Old Nov 22, 2009 | 07:07 AM
  #63
well, the title is 2", no telling what was meant. It's just nice to have the accurate info.
Old Nov 22, 2009 | 09:58 PM
  #64
RDFABS_Cody's Avatar
Well I am not here to plugg our products because it is against the rules here, however I was directed by a member from JBO to a guy here who has been dyno testing exhaust manifolds. Were are looking into see what is required of us to make this happen by the member on here, and I guess those numbers will then speak for itself.
As far as the diameter were talking about here, yes the tubing is 2" OD and then 16ga thickness which makes it 1 7/8ths. That's just how its sold from our supplier.
Old Nov 23, 2009 | 12:58 AM
  #65
DaFlyinSkwirl's Avatar
I would buy it based on the collector alone. verrrry nice merge.
Old Nov 23, 2009 | 06:36 AM
  #66
x2, I was gawking over that collecter as well. This is a very nice piece.
Old Nov 23, 2009 | 11:52 AM
  #67
spike's Avatar
first time i have seen someone take the time to care about that part +3
Old Nov 24, 2009 | 10:40 PM
  #68
Edubs's Avatar
That's why I've had RD Fabs work on all of my setups. Quality hand-built products that are warrantied...
Old Nov 25, 2009 | 01:39 PM
  #69
phatnackySS's Avatar
Originally Posted by selfinfliction
honestly it's not worth it think about this:
4 x 1.5" = 6" area for exhaust to travel through
4 x 1.75 = 7" area
4 x 2" = 8" area
all three of which, go right into at the biggest a 1 x 3" pipe. this is why i find it funny when people argue about how much better a 1.75" primary header is than a 1.5" primary header the more volume you have, the slower the velocity. the slower the velocity, the less scavenging effect you have. so bigger on everything, isn't always better.
Expect for the fact that Exhaust is pulsed ... engine exhaust isnt all crammed together into one pipe , each pusle form each cylinder is separated form one another,imagine each exhaust pulse fallowing another in a single file line ,and not side by side.
2" primaries do seem large on a 2.0L engine until you think about how much power some guys are making on tvs,or nitrous, 3-400hp is a lot of air to move , you figuer a v8 makes 400hp while running 1-7/8 primeries ,but thats x 8 cylinders , theoretically you would need over 3" primers to flow the same amount of air on a 4cyl engine (excuse the gorilla math ) when you think of things volumetricly 2" really isnt that big.
Old Nov 25, 2009 | 05:22 PM
  #70
most v8 guys dont run 1 7/8 primaries for 400hp builds...not even 400whp builds.
Old Nov 25, 2009 | 08:34 PM
  #71
This is the crowd we are trying to appeal to, those looking to make some larger numbers where the current applications available just are not sufficient for their needs.
Old Nov 26, 2009 | 12:07 AM
  #72
Maven's Avatar
600hp builds dont even require 1 7/8" primaries. a 2" primary on a smallblock V8 is HUUUUUGE.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
tomj77
Oct 4, 2015 11:39 AM
ThoR294
Sep 28, 2015 05:31 PM
goaliemo
Sep 28, 2015 01:37 PM
