Summer Tune Question
Old Jun 4, 2011 | 08:18 AM
QuickSilver_SS's Avatar
Question Summer Tune Up Question
Over the next day or two i am going to be giving my car a little tune up. I plan on replacing my plugs, air filter , Oil & filter as well as my gas filter. My question is about which plugs to use. Should I use just the GM stock replacement spark plugs ? Or should I use the NGK BKR7E 's ?? I can't decide which one to run. Hence the post. Does one plug offer better performance over the other plug in our cars ? My current mods are GM stage 2 with the air box mod. I also have a cobalt addiction heat exchanger. Thats it really..... Any thoughts ?
Thanks
Old Jun 5, 2011 | 10:45 AM
Anybody ??
Old Jun 5, 2011 | 10:49 AM
Chevycobaltss3's Avatar
Use the ngk. They are rated by heat..... You will get spark bblowout and you will get kraft. If u use the stock plugs since Ure on the 2.9 get one step colder.
Old Jun 7, 2011 | 07:22 AM
What is kraft ?? Also... I am currently on the gm stage 2 pulley. I removed the 2.9" for the time being. Which plug is best to run on just the gm stage 2 ?
Old Jun 7, 2011 | 07:28 AM
05Slowline's Avatar
knock retard at full throttle i think
can just get bkr7e
Old Jun 7, 2011 | 07:57 AM
Staged07SS's Avatar
Administrator
Administrator
This needs to be clarified.
OP, you will not get spark blowout from use of the stock plugs.... Spark blowout happens when the gap of the plugs is large enough for the incoming air to "blow out" the spark. To fix this, you simply close up the gap (if you are even experiencing this issue).
1-step colder is the heat range, and for your particular setup 1-step colder or even the stock plugs will be fine.
Old Jun 7, 2011 | 10:04 AM
You will get kr and possible spark blowout with the incorrect plug and gappage. Lol i Hate my phone sorry...... Kraft =kr. Lol spellcheck Hahahaha...
Old Jun 7, 2011 | 10:41 AM
Staged07SS's Avatar
Administrator
Administrator
That's better
Old Jun 7, 2011 | 11:36 AM
Lol.... I was wondering what kraft meant. Knock retard makes more sense....
Thanks for the feedback staged07.... I already have a set of the NGK bkr7e's. They are not installesd. I was just curious if I was better of to install them or a NEW set of stockers. And which offers better performance...... Also, where the ngk's are copper. How long will they last ?
Old Jun 7, 2011 | 11:44 AM
Staged07SS's Avatar
Administrator
Administrator
Most change the coppers out every other oil change.
Old Jun 7, 2011 | 11:55 AM
Lol.. I wrote my mom a text once. It was supposed to say i need to fabricate my New pole alittle so it'll work. Well my text came out saying anything i need to ********** my pole a little bit so it'll work Lmao.... Love my life.. But op back to topic lol.. I thought i might give you all a laugh....
Old Jun 7, 2011 | 11:56 AM
Staged07SS's Avatar
Administrator
Administrator
Old Jun 7, 2011 | 01:16 PM
My android does the same bloody thing. It spell checks every word even when there the correct spelling hlaf the time I find it changes it to another word. All krafty and sneaky like. Without me realizing it. Then I end up texting pure nonsense to my wife or friends.
Anyhow... Every other oil change the coppers should be changed. I was hoping to put something in that lasted a bit more then every other oil change. Great... Now the debate gets even harder....
Old Jun 7, 2011 | 01:29 PM
Staged07SS's Avatar
Administrator
Administrator
I was just stating what I've heard from members using coppers & their change intervals. That's the only downfall of copper plugs. Changing plugs on our cars is easy. I wouldnt disregard them, because you have to change them more often man.
I use iridiums.
Old Jun 7, 2011 | 07:50 PM
05Slowline's Avatar
meh i had my shitty autolite plugs in cause autozone and napa didnt have the bkr7e when i needed them in for like a year and a half...they worked fine just black tips from running gms2 tune on it for half a year lol
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Extremespeed
Sep 29, 2015 04:34 AM
