Summit mufflers.
Old Jul 26, 2008 | 07:05 PM
Perfect.disguise's Avatar
Summit mufflers.
Has anyone tried the Summit brand turbo mufflers?You need a center offset muffler correct?I have a Header/Dp and I'm trying to be cheap on a muffler / resonator. Whats the cheapest muffler that will sound decent?No canister mufflers btw.
Old Jul 26, 2008 | 07:10 PM
UmeNNis's Avatar
no idea. bump for ya
Old Jul 26, 2008 | 07:14 PM
camarokiller's Avatar
Go with the polished summit muffler, its what i run after my cutout. Its quieter than stock but it flows great! http://store.summitracing.com/partde...5&autoview=sku
You need a center inlet/outlet BTW
Old Jul 26, 2008 | 07:22 PM
So sounds good?I'm going to be running a Vibrant Hdr/Dp with a gutted cat until it is replaced.I'm looking at the Summit turbo and a magnaflow resonator. I don't want it to be that much louder than stock. It also needs to be a "turbo" muffler correct?
Old Jul 26, 2008 | 07:28 PM
I ran it with a pacesetter header 3 inch catless dp, and two 3 inch 24 inch long glasspacks, it was quieter than stock untill i opened the cutout.
Old Jul 26, 2008 | 10:23 PM
Searching around I see most people use an offset inlet and center outlet.. Is that correct?
Old Jul 26, 2008 | 10:32 PM
I made 3 diffrent setups for my car and used center in/out for all and they all fit perfectly. The pipe over the rear axle points straight at the opening in the bumper i dont see how a center in/ofset out would work.
Old Jul 26, 2008 | 10:48 PM
Whats the diff between the ceramic packing in the summit muffler that you posted and a "turbo" muffler? Both single chambered?
Old Jul 26, 2008 | 10:53 PM
theneelster's Avatar
Don't be cheap on the cat back components it will sound like ****...sorry to break the news.
Plus you need a tip with that muffler so that's at least 20 bucks shipped.
Last edited by theneelster; Jul 26, 2008 at 10:53 PM. Reason: Automerged Doublepost
Old Jul 26, 2008 | 11:01 PM
Ehh, a mufflers a muffler.Not like it's some POS eBay fart can.Re-using my stock tip.
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
Blackout06LS
How to Guide
38
May 13, 2008 09:42 AM
