Supercharger noise on shut down- help
Old Nov 12, 2010 | 10:52 PM
BCobaltSS's Avatar
So I have heard this noise coming from the engine bay when I'm shutting down the car that sound like two light pieces of metal are slapping against each other. I used a stethoscope and found that the noise was coming from the supercharger nose cone. I don't think that its the SC coupler because all that I have read is that the coupler fails and at idle you can hear marbles bouncing around. Mine is not like that. Any insight will be helpful. Oh and the pulley stops turning and it's as if stop after winding down.
Any thoughts?
Old Nov 12, 2010 | 11:00 PM
ItalianJoe1's Avatar
You sure it's not the TB closing sequence? It makes a metallic click sound after the motor stops and it snaps back to neutral position.
Old Nov 12, 2010 | 11:04 PM
chrisjaldin's Avatar
I'm having a wierd sound on my engine bay also..Mine if you upload a vid?
Old Nov 13, 2010 | 10:17 AM
Silv3r's Avatar
Pretty sure Joe nailed it, I've heard that noise since I bought my car. It sounds like a very tinny clinking noise about 1 second after the key is turned off. It's normal
Old Nov 13, 2010 | 06:55 PM
BCobaltSS's Avatar
So it's the damn throttle body. I sounds like it's rotational though like a clinking noise . I will have to check it out tomorrow. I did not know that the TB went through a shut down sequence. weird. I can't upload the video of it sorry
Old Nov 13, 2010 | 11:53 PM
Yeah, the TB normally is in a fully closed position at idle, at least just about closed. Once the motor stops turning, the TB releases to it's middle position and it makes a loud metallicy click noise.
Old Nov 14, 2010 | 01:03 AM
BCobaltSS's Avatar
Interesting I will check it out
06MetallicBalt
Jul 20, 2025 08:47 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
