supercharger pulleye removal
ok quick question my buddy says that for cobalt you need to remove the supercharger in order to remove the stage 2 pulley off the hub, but he says due to better clearence you can just take the pulley off on an ion without taking the charger off. But i took a look and there looks to be ample clearence to take the stage two pulley off my cobalt. What do you guys think?
If you are already staged...then yes I have witnessed/aided-in doing so without removing the pulley. I have the Ingalls ETD so I can just zip-tie my belt to the ETD once I take the slack out of it. Just remove the four bolts holding the ring in place and then remove...replace with new pulley ring. *But make sure that the new ring is designed to fit the stage 2 hub from GM* But don't get me wrong it's a hassle for sure. But we did the swap on the parking lot for our dyno
So it doesn't take long at all.
so the stage 2 pulley isnt pressed onto the hub is it?
16 ft-lbs of torque with one drop of loctite red on the threads
patooyee
Oct 1, 2015 01:07 PM
z28addiction
Sep 28, 2015 12:03 AM
