supercharger snout question
Old 12-28-2011, 04:25 PM
SlowCobaltSS's Avatar
Ok so correct me if Im wrong here but dont we need to grind down our supercharger snout to run anything smaller then a 2.7 pulley?
And how much would I need to remove if I wanted to run a 2.6 pulley?
Old 12-28-2011, 04:31 PM
USA Y U NO HAVE AUTOBAHN?
tylerjclance's Avatar
No.
I have the ZZP 2.6 on my m62 with their hub,
no grinding needed.
Just a pulley puller.
Last edited by tylerjclance; 12-28-2011 at 04:31 PM. Reason: Automerged Doublepost
Old 12-28-2011, 04:39 PM
Ok kool thanks,
I know that every car is different and all that but how much boost are you on with the 2.6
Old 12-28-2011, 04:50 PM
Got Bewst?
Bluelightning's Avatar
Yeah it all depends on the hub and pulley style. I had to grind mine down to fit my 2.6" smooth flow pulley. As for boost there are so many variables to say you will make XX psi. I make 19 psi with my 2.6" pulley and current set up.
Old 12-28-2011, 05:45 PM
Reaper06's Avatar
2.7-15.8 2.6-16.4 2.5- 17.9 2.4-19 all cars little diff but thats what i made per hp tuners, not the oem gauge.
Old 12-28-2011, 06:29 PM
Got Bewst?
Looks about right to me. I run meth through my blower so that bumped it up about 2psi. Without that I'd be in the 17 psi range.
Old 12-28-2011, 07:30 PM
Reaper06's Avatar
I run meth aswell. I belive most diff come with how far your setup to rev out.
RaginChopsuey
10-27-2015 01:27 PM
brandon04
10-21-2015 07:04 AM
Extremespeed
09-29-2015 04:34 AM
Iceberg
09-28-2015 01:31 PM
z28addiction
09-28-2015 12:03 AM
Quick Reply: supercharger snout question
