Supertech Issues
Supertech Issues
Hey guys
I have a set of Supertech 75's installed. Installed the cams into the head and the cams won't turn a full rotation.
Springs dont appear to be binding. They cant really be installed wrong. All the keepers went in fine.
Had the lash adjusters out and in oil. Could they be over expanded?
all the springs dont make any contact with the head. The outter springs are not being compressed all the way. It is hard to see but I dont believe the inner springs are also being collapsed. The seat for the inner spring was installed.
Head with the supertech springs is on the engine. The cylinder the the lobes were pushing down, we made sure the piston was at the bottom.
The head with the factory springs was on the bench
no matter what cylinder you have at the bottom you will always have 2 at the top so I would say the reason why it wont turn over is the valves hitting the pistons if you want to rotate the cams then put the pistons(all 4) in the middle of the stroke
that doessent matter because if any of the pistons where still too high then you can still contact them.
I mean if a motor stops you should never force it just back it off and asses what it going on before you do damage
bingo was his name o
The cam will make it about 75% to the tip of the cam before it jams.
Happens both on bench and on veh.
We tired with all the pistons in the middle of their stoke so it would be impossible for the valves to hit anyways.
Only thing I can think of is the Year of the head is unknown since bought used off mongo. I don't think any changes to the head happened though the LSJ years thou
the only other couple of things that would keep the cams from rotating is coil bind or the retainer hitting the valve guide
I ran the zzpstg2 cams with no problem of binding or hitting
Found out the problem.
After a few weeks of just not caring I went back to the car to find the problem. I know it is something in the valves/springs as I tired everything else.
Took the springs off to check for problems. The seats for the inner seats were installed upside down. I guess it would cause the inner springs to compress flat and stop the cam.
Removed them all and installed the right way and cams turn as they should.
Just as I get all excited to finally get things back together, my brand new timing chain has a twisted link. FML
