Supertech Issues
Old Jul 6, 2013 | 07:03 PM
dwarrick's Avatar
Supertech Issues
Hey guys
I have a set of Supertech 75's installed. Installed the cams into the head and the cams won't turn a full rotation.
Springs dont appear to be binding. They cant really be installed wrong. All the keepers went in fine.
Had the lash adjusters out and in oil. Could they be over expanded?
Old Jul 6, 2013 | 07:11 PM
Tjolley's Avatar
well theres nothing eles to stop the cams from turning.
R u using stock cams??
Old Jul 6, 2013 | 07:19 PM
dwarrick's Avatar
ZZP stage 2.
We put them in a head with stock springs and they worked fine.
Old Jul 6, 2013 | 07:26 PM
Tjolley's Avatar
The supertechs will be way stiffer and make it harder to turn the cams. U try aplying more force to turn them?
Old Jul 6, 2013 | 07:40 PM
dwarrick's Avatar
Yup. Snapped 4 of the rockers on one side.
Old Jul 6, 2013 | 07:42 PM
Omiotek's Avatar
theres something else going on here.... take the cams out and inspect the springs. also check the spring to head clearences. the springs sometimes hit the casting
Old Jul 6, 2013 | 07:58 PM
dwarrick's Avatar
all the springs dont make any contact with the head. The outter springs are not being compressed all the way. It is hard to see but I dont believe the inner springs are also being collapsed. The seat for the inner spring was installed.
Old Jul 6, 2013 | 10:17 PM
mrbelvedere's Avatar
was the head on the engine
Old Jul 6, 2013 | 11:07 PM
dwarrick's Avatar
Head with the supertech springs is on the engine. The cylinder the the lobes were pushing down, we made sure the piston was at the bottom.
The head with the factory springs was on the bench
Old Jul 7, 2013 | 12:13 AM
no matter what cylinder you have at the bottom you will always have 2 at the top so I would say the reason why it wont turn over is the valves hitting the pistons if you want to rotate the cams then put the pistons(all 4) in the middle of the stroke
Old Jul 7, 2013 | 03:29 AM
Omiotek's Avatar
i have to agree with mr b if everything iI said checks out. If you broke rocker rollers you will be lucky to have not of bent valves
Old Jul 7, 2013 | 08:44 AM
dwarrick's Avatar
cams do not have gears or chain installed, we we are only moving one cam at a time. This way we are only opening one set of valves.
Old Jul 7, 2013 | 09:38 AM
Omiotek's Avatar
that doessent matter because if any of the pistons where still too high then you can still contact them.
I mean if a motor stops you should never force it just back it off and asses what it going on before you do damage
Old Jul 7, 2013 | 10:27 AM
and if a piston is at tdc you will smack the piston with a valve these are interference engines
bingo was his name o
Old Jul 7, 2013 | 11:15 AM
JapEatr's Avatar
South Central *********
Yup... Your cams are 120* out, to get them in phase, you will need to go BDC or half stroke depend on with 1/3 rotation you are stuck in
Old Jul 7, 2013 | 11:29 AM
TStone's Avatar
oh god bless your soul dwarrick
Old Jul 7, 2013 | 12:38 PM
dwarrick's Avatar
How would the valves hit?
Regardless head is off the car. No marks on pistons. No bent valves. Re assembles and tested on bench. Cams still not turning.
Old Jul 7, 2013 | 12:56 PM
dwarrick's Avatar
The cam will make it about 75% to the tip of the cam before it jams.
Happens both on bench and on veh.
We tired with all the pistons in the middle of their stoke so it would be impossible for the valves to hit anyways.
Only thing I can think of is the Year of the head is unknown since bought used off mongo. I don't think any changes to the head happened though the LSJ years thou
Old Jul 7, 2013 | 02:52 PM
Omiotek's Avatar
sounds like theirs a fitment issue with the springs.... did a machinest do all of the work and a valve job?
Old Jul 7, 2013 | 02:56 PM
the only other couple of things that would keep the cams from rotating is coil bind or the retainer hitting the valve guide
I ran the zzpstg2 cams with no problem of binding or hitting
Old Jul 7, 2013 | 03:39 PM
dwarrick's Avatar
It has to be something with the springs. They were installed when they head got a valve job, port and polish.
Think I'm gonna swap then for a set of ZZP or werks ones
Old Jul 7, 2013 | 03:52 PM
Omiotek's Avatar
werks ones are made here locally. I can set you up with um when your ready if that's the route you want to go.
Old Jul 25, 2013 | 09:14 PM
dwarrick's Avatar
Found out the problem.
After a few weeks of just not caring I went back to the car to find the problem. I know it is something in the valves/springs as I tired everything else.
Took the springs off to check for problems. The seats for the inner seats were installed upside down. I guess it would cause the inner springs to compress flat and stop the cam.
Removed them all and installed the right way and cams turn as they should.
Just as I get all excited to finally get things back together, my brand new timing chain has a twisted link. FML
Old Jul 25, 2013 | 09:56 PM
mongorat427's Avatar
Good deal
Jan 12, 2016 12:01 AM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
