taking forever to start...
Old Mar 31, 2008 | 11:51 AM
sherm420's Avatar
I'm at about 55k in my 06 ss/sc and for the last week when i go to crank the engine it takes it about 13 tries b4 it cranks up.. all in the same attempt though. Now could this be due to the battery or starter...just wonderin if its hapened to anyone else yet
Last edited by sherm420; Mar 31, 2008 at 11:53 AM. Reason: edited to make more clear
Old Mar 31, 2008 | 11:53 AM
invisible's Avatar
Try checking you're spark plugs.
JPizzle's Avatar
Damn! I don't know.....
Old Mar 31, 2008 | 11:58 AM
LopsidedJester's Avatar
well, 13 tries of cranking before it fires up or 13 tries before it cranks, not cranking is usually signs of starter or bad battery connection. If you had a bad battery it would have probably drained to nothing and gotten worse with every try, spark plugs could definitely be a problem if it takes a while for the engine to actually start while its cranking.
Old Mar 31, 2008 | 11:59 AM
sherm420's Avatar
^^ 13 tries of cranking b4 it starts
invisible's Avatar
If it just recently started, than It might be bad gas to.
Old Mar 31, 2008 | 12:35 PM
have you ever changed your plugs from stock, cause it sounds like spark problems, bad gas is pretty rare, i've never had a batch of bad gas that didn't allow my car to start.
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 20, 2015 09:56 PM
