Tbandit's Build Thread!!!!!!
Old Dec 19, 2011 | 07:44 PM
tbandit420's Avatar
So finally i get to make one of these :-). so i finally picked up the crate engine from the guy off of css.net. Its the jbp mild crate motor its in perfect condition includes diamond pistons 9.5:1 compression, total seal gapless piston ring kit, diamond thick walled piston pins, diamond spirolox, jbp sportsman connecting rods with arp bolts, gm main bearing, gm connecting rod bearings, gmpp neutral balance shafts, and jbp strengthened crankshaft. for all the people thinking why would u buy a jbp engine? well i only paid 250 bucks for it so **** it lol. Heres a list of what else im picking up over the next few months.
zzp valve springs
zzp s2 cams
P&P head
zzp dual pass endplate
gmpp clutch
zzp stage 1 axles
zzp rotated front and rear tranny mounts
ssc springs
kyb shocks and struts
either 2 16 rims with slicks or 2 17's with drag radials
zzp phenolic spacer
zzp brfp system
zzp fuel pump rewire kit
I plan on re dynoing my current setup then once the motor is broken in dyno again with the m62 still and from that point either go with a 75-150 shot or slap a tvs on it. now on to current pics.
my goal is to hit over 400whp but we will see what happens. i will update the list with pics as i get more parts. and im open to any and all opinions on the build. thanks for reading.
Old Dec 19, 2011 | 07:47 PM
Mindrot's Avatar
I'm still puzzled how you got it for $250
Old Dec 19, 2011 | 08:00 PM
tbandit420's Avatar
**** i just shot him the offer and he said yes. some times it dont hurt to ask lol
Old Dec 19, 2011 | 08:15 PM
mrbelvedere's Avatar
good buy but you cant make a stock crank that will hold over a thousand hp stronger
Old Dec 19, 2011 | 09:20 PM
tbandit420's Avatar
i think they just coated it or something who knows
Old Dec 21, 2011 | 03:53 PM
tbandit420's Avatar
So any opinions or suggestions. Anyone think my goals are realistic or have a guess of there own on what my number would look like with this build, current mods on the m62 and then on the tvs?
Old Dec 21, 2011 | 04:08 PM
jonnymerk's Avatar
Dunno, my sleeve is what went on my motor so I always cringe a little when people build a motor and don't replace the next weakess link that just got knocked down a few more pegs lol. For such a low price tho I would have paid 5 times that a month ago when my motor blew.
Old Dec 24, 2011 | 05:50 PM
tbandit420's Avatar
so i updated the first pots with some more parts i realized i should get. any opinions on the zzp brfp system. you guys think a fuel pump rewire kit and the zzp system with stock fuel pump and 80's will be enough for e on should i get a walbro 255 also. also any opinions on if i should get 16's and slicks or 17's and drag radials? what do you guys think will work best for the power im looking for and with the ssc springs. also any opinions on the kyb springs. as always any and all info and opinions given is appreciated.
Old Dec 24, 2011 | 08:09 PM
the stock pump is better then a walbro 255 you will need more pump if you get serious with e
Old Dec 24, 2011 | 08:29 PM
BlkWdoSS's Avatar
Damn nice deal on the motor. Nice build plans, how far do you plan on revving? Stock rev, probably only get to 350-370 on the TVS. I think only one or 2 people have broken into the the 400s with a TVS and they were revving out into the 8k region.
Turbo will get you more HP in the end, just more expensive to set up.
The ZZP BRFPS is an ok system but Return Style really is the way to go, and not too bad to set up.
Good luck with the build and congrats.
l8r,
PD
Old Dec 24, 2011 | 11:55 PM
tbandit420's Avatar
im looking to rev it to 8k, hell with the zzp stg 2 cams will take my power band to right before or right at 8k with my gmpp neutral balance shafts and p&p head. on a tvs my power band will prolly peak around 8200rpm or so im told.
Old Dec 25, 2011 | 03:19 AM
BlkWdoSS's Avatar
kool, 400 would be possible then, hope it goes well
l8r,
PD
Old Dec 25, 2011 | 07:46 AM
jgarciarivera's Avatar
Walbro 255lph Fuel Pump - GSS342
HP Rating: Up to 600hp Design: Intank Flow: 255LPH High Pressure Minimum Voltage: 12V Operating Pressure: 35-100psi Part Number: GSS342 with Installation Kit
By the way, good luck with the project. Keep up posted.
06MetallicBalt
Jul 20, 2025 08:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
riceburner
Oct 2, 2015 05:47 PM
