Thinking about converting 07 SS SC to turbo
Old Nov 3, 2010 | 04:12 PM
jmo2010's Avatar
I was wondering what would be a good turbo conversion kit for the 300-400 hp range of a DD. Also what are the + and - for switching from what i have.
Most important thing is safety and longevitiy of the motor.
I was possibly looking into a hahn kit.
Also what supporting mods? I know i need gauges, most likely a upgraded clutch, and 3" catback exhaust...
ANY HELP/INPUT/OPINIONS APPRECIATED! Thanks a ton!
Old Nov 3, 2010 | 04:17 PM
hungryhip-ccp's Avatar
The best advice i can give you is research research research... I jumped into it head first with the hahn kit... What a huge waste of money it was in the end. ut thats just imo
Lifter's Avatar
IMO, if you're going over 300HP (with the hahn kit) I'd play it safe and upgrade several things.
Axels (because the stock ones are not that powerful)
3in Exhaust
DP with high flow cat or catless
Get your Interceptor
Get a good clutch (rated for 300+HP)
Upgrade your mounts
And etc...
Old Nov 3, 2010 | 04:21 PM
INFE's Avatar
I pieced together my own kit and worked out good for me but u have to research the **** out of everything.
Old Nov 3, 2010 | 04:42 PM
Studmuffin02's Avatar
I did the Hahn stage V kit, love it. no problems yet and expect to go to 22 psi stock internals but need to get a clutch. Its chunck of change but its for quality product and for their credibility.
Old Nov 3, 2010 | 04:46 PM
jmo2010's Avatar
Ya thanks. I"m lookin around alot. I'm possibly going to go with hahn level 5 and keep the boost low and safe. I wish I wouldn't of just jumped into my stage kit but anyways I'm forcing my self to do all the supporting mods first lol but i'm gonna think alot about it. But thanks for the info keep it comin.
Old Nov 3, 2010 | 04:49 PM
rico's Avatar
piece it together better off that way and its so worth it
Old Nov 3, 2010 | 04:52 PM
if you go with a hahn kit on low boost your car will make a slightly higher peak hp but it will be no faster than a "bolt on" car if your talking 1/4 times.
the power band is well not the prettiest... that turbo doesent full spool till 3500+
the only way it will be faster is if you run 18+psi i ran 23psi and ran 25psi for a little bit but traction was completely gone when the boost hit.
and then it just spun instead of accelerating. the way the boost came in on my S256 was way better and more controllable. and the spool times were the same as the old ass 20G
Old Nov 3, 2010 | 05:37 PM
1fastSSBalt's Avatar
Op I was thinking of doing the same with my 07. I hear the ZZP turbo kit is pretty nice even though it isn't the "prettiest" of course if you want numbers over looks for a DD I'd research that and talk to people that have used/use that swap kit.
Old Nov 3, 2010 | 05:45 PM
SS FREAK's Avatar
do it bro!! i did and love it! but go with precision you cant go wrong there! good luck
Old Nov 3, 2010 | 08:50 PM
jmo2010's Avatar
i didn't think you could order one, i thought you had to drive to them and have them put it in? on their site is said something about no shipping
Old Nov 4, 2010 | 12:01 AM
Your thinking of ZZP's twincharge kit. That is something completely different.
bigdeertz
Nov 17, 2016 09:41 AM
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
OPCrer
Sep 27, 2015 08:11 PM
