Those of you with the hastrickstu cooling mod
Can someone tell me/show me where to route the coolant hoses? I got one of them through underneath the headlight but there is absolutely no room for the second hose. I've tried everything but can't figure it out.
I'm assuming that's the bottom hose under the headlight, if so good. For the top hose:
Right in front of the SC pulley, reach under the top radiator support beam. you'll feel that there is enough room to tuck the hose in there around the pulley and you can use a zip tie to hold it in place so it doesn't slip down and rub the pulley/belt. I don't have a pic anymore to show you exactly, but I think you'll see what I mean.
where is yours leaking, i havent had a single one of the second designs leak. were you tugging on the connections hard?
its leakin on the top, i have it on as tight as it goes but it continues to leak. not a lot just enough to leave like a 3-4in circle under my car everytime i move my car after it being parked. it only leaks around corners
