thowing a cel with airbox mod
Old Apr 15, 2008 | 04:35 PM
venum_us_2002's Avatar
I started throwing a CEL now that i did the airbox mod so i took it into the dealership cuzz i had a lot of other problems to and they said the reason i am getting a cel is because i am running to lean so i need to put the airbox back to stock? What do you guys think
Old Apr 15, 2008 | 04:39 PM
rnjmur's Avatar
Sounds like they should probably check to see if it needs the reflash to correct that problem. If it has been reflashed then it is hard to say.
Old Apr 15, 2008 | 04:42 PM
Originally Posted by rnjmur
Sounds like they should probalby check to see if it needs the reflash to correct that.
But there saying if i put the bottom part of the airbox back on it will correct it. I cant see how taking off the bottom of the airbox can make your engine run that lean to throw a cel
Old Apr 15, 2008 | 04:59 PM
07 SS/SC's Avatar
That happens to just about everyone. Nothing to worry about, it is prolly the most common code thrown on our cars. What it is doing is giving the MAF a different reading setting off the CEL, dont worry about it.
Old Apr 16, 2008 | 01:03 AM
rnjmur's Avatar
Yes what he said. There was a reflash to correct the problem... however it doesn't correct it all the time.
Old Apr 16, 2008 | 12:50 PM
if i just leave it will it be okay?
Old Apr 16, 2008 | 12:53 PM
SSCobalt~SSZ24's Avatar
yea the mafs are VERY sensitive
turbochargedss2012
Sep 20, 2023 12:17 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
DocSvensk
Sep 27, 2015 02:24 PM
