Throttle Lag Please Help!
Old Oct 23, 2006 | 08:55 AM
codyss's Avatar
Alright for the last couple of days my car has had a throttle lag issue.
I step on the gas and it seems like it takes a few seconds before the car actually accelerates. The revs come up but slowly and there is a delay in the S/C kicking in which makes me think vacuum is dropping slowly.
I am not making any more boost so I would assume it's not a CAT issue.
The only other thing I can think of is issues with communication between pedal and the throttle body motor or a f'ed up throttle body motor. It seems to open quickly but maybe not 100%.
That or the cold weather stratagy for these cars is really, really terrible. It has the same issue cold or hot and when its 38 degrees or 60 degrees outside.
Any ideas would be helpful, since I don't want GM doing WOT tests in my car to duplicate the lag.
Thanks
Cody
Old Oct 23, 2006 | 09:15 AM
g5mike's Avatar
we can do a group prayer for a great aftermarker TB
Old Oct 23, 2006 | 10:17 AM
cds00bsmg's Avatar
Do you have the most current flash of Stage 2 by chance? I sometimes have a little throttle bog first thing in the morning. After the car is up to operating temp. it irons out though.....
Old Oct 23, 2006 | 11:38 AM
lsjwannabe's Avatar
if you have hp tuners it is a easy fix i have a 2.5 and 60's though so i don't know if your problem is the same as mine was.
Old Oct 23, 2006 | 05:34 PM
codyss's Avatar
All I have is Stage 2 with the new update.
It was just fine until last monday the the trouble started, it was running awesome that previous friday night.
Old Oct 24, 2006 | 03:46 PM
Julex's Avatar
Check the Cat, once it starts going you'll notice accelerating will bog, or worse like what mine did, is just allow almost no passage(I'm glad my exhaust gasket and not a headgasket or something) but I would say check it, before you do any more accelerating! A buddy of mine blew his engine cause the cat clogged like mine and when he started it up, caused a vacuum and sucked the cat internals right throught the exhaust ports and blew the engine. Cracked piston, broken valves, ring damage.... a great big mess.
Old Oct 24, 2006 | 03:53 PM
cawpin's Avatar
That isn't possible. Exhaust ports only flow one way.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
TylerJHowell
Sep 21, 2015 06:47 PM
yellowsupercharged06
Sep 15, 2015 04:38 PM
