throttle positioning sensor
Old Mar 4, 2008 | 11:47 PM
cobaltz51r's Avatar
when i get it tuned im getting the TPS sensor taken out and my speed gov. taken out with the tps out will i get more psi of boost or just get the full 19 psi im kicking out now????
Old Mar 4, 2008 | 11:49 PM
Red2.4SS's Avatar
TPS removed?
You need it for the drive by wire?
eastcoastz's Avatar
No bro you car would not run without a TPS which in our cars is part of the throttle assembly.
Old Mar 4, 2008 | 11:54 PM
cobaltz51r's Avatar
no no im srry i wasnt clear with that i dont mean taken out like totally disassemble it im saying when i have my computer tuned he says he can change the tps as in make it open up all the way when i put my foot to the floor because the stock computer tells the tps to rapidly open and close the throttle holding our engines back i ment reprogram not disassenble it im srry
Old Mar 5, 2008 | 12:10 AM
Sharkey's Avatar
the computer doesnt flutter the throttle body to hold back power. what it does do is regulate how quick it opens as part of the torque managment stratagy. it also opens the bypass valve part way in 1st gear to limit boost.
Old Mar 5, 2008 | 12:20 AM
Nyke's Avatar
Torque management is key in first gear, go as open as you can on it before you start to wheel hop / loose traction.
Traction mods will make you be able to go faster, some people invest in these mods first.
I am going about this route, so far i went with Stage 2 Kit and I have ZZP Tranny mounts and Motor mount. Wheel hop has been eliminated now i just need to get traction, so wider tires are next, 235/45R18 (maybe 245/40r18) if that doesnt then some traction bars and suspension drop. Once i can get all my power to the ground without slipping then I will build up even more, until then. What the point in having power if you cannot use it.
Old Mar 5, 2008 | 12:29 AM
Red2.4SS's Avatar
I would rather do my own torque management myself.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
jmelton327
Sep 26, 2015 10:04 PM
