Throwing Codes Please HELP !! ! ! ! ! ASAP SOS lol
Old Nov 8, 2009 | 06:04 AM
Winkdogydog101's Avatar
ok so i took the whole supercharger off and tb and ported both of them. I did put everything on in a rush and i forgot a hose so my check engine light came on, on my way to get gas. i knew i forgot something found it restarted my car and it was off. so i go out to race and beat a mustang GT and threw a code and engine power reduced and pulled off to the side of the road. When i restarted the car it seemed like one of my sparkplugs went bad but when i scaned it i HAD
P1516 map control, Idle Speed control, and Exilliary Input
AND
P2101 Tac Motor, CRT range /PERF
and i cleared them and drove home fine then on my way home my P1516 came back.
ILL check everything more tomorow but i was just wondering did i miss something or is something engine wise wrong cause i about **** my pants when my engine power was reduced cause i thought i blew something lol.
THanks for the help guys im posting pics the first time my i changed the hose from the boddom of the black part in the first pic to the top and it didnt do anything just wondering if i have everything right
Old Nov 8, 2009 | 09:29 AM
selfinfliction's Avatar
plug it all up, unhook your battery, turn the key over to suck all the juice left in the system. turn it back off and hook up the battery
Old Nov 8, 2009 | 09:43 AM
cobaltltblue's Avatar
Take the stupid hand writing off the valve cover. THATS the problem.
Old Nov 8, 2009 | 02:28 PM
hey thanks ill try that i need help with this for sho
Old Nov 8, 2009 | 11:13 PM
SSfamilywagon's Avatar
Check the sensor on top of the sc. Did you leave it on while porting? It prob has shavings in it.
Old Nov 9, 2009 | 09:45 AM
boosted2.2's Avatar
It's probably the plate in the tb. Make sure when you put it back in, it's centered. Also make sure there is nothing blocking it for moving.
Old Nov 9, 2009 | 10:20 AM
qwikredline's Avatar
the vacuum line is missing off the boost solenoid. it goes downhill from there; piktar 8 has a sensor connector unplugged. Yikes! This is a messy job you got done doing there.....power wash entire car and hire qualified tech....
Old Nov 9, 2009 | 10:37 AM
StageII07's Avatar
You should clean your motor up..you have that nice shiney Red blower but the reest of the motor is dirty..
Just wanted to add my 2 pennies
Old Nov 9, 2009 | 12:39 PM
damn
damn 2.2 nice you got it yea i took everything apart and the peice inside the t/b was all messed up so i sanded it down and got it in thanks guys for all your help
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
Oct 13, 2015 09:32 PM
Extremespeed
Sep 29, 2015 04:34 AM
