Timing?
Old Aug 2, 2009 | 09:04 AM
07touringcoupe's Avatar
Timing?
I was wondering what is the timing of a stage 2 s/c during crusing and at wot?
Old Aug 2, 2009 | 09:10 AM
Zach06CobaltSC's Avatar
It changes when you are cruising depending on what level of boost your at and what rpm you are at. But when your wot in a stage 2 car the timing is set at a max of 15 degrees.
Edit: If you want I can post a screen shot of the stage 2 high octane map so you can see how it works.
Last edited by Zach06CobaltSC; Aug 2, 2009 at 09:10 AM. Reason: Automerged Doublepost
Old Aug 2, 2009 | 09:11 AM
im saying not in boost at crusing. In vaccum
that would be great
Last edited by 07touringcoupe; Aug 2, 2009 at 09:11 AM. Reason: Automerged Doublepost
Old Aug 2, 2009 | 09:12 AM
It still depends at what cyl air mass your at and what rpm you are at. We will say roughly 30-40 degrees though if that makes you feel better.
Old Aug 2, 2009 | 09:15 AM
o ok i got you. So i adding so timing at wot would increase my hp and lowering it would increase tq? That was hear say and im just trrying to understand it
Old Aug 2, 2009 | 09:17 AM
flash13brandon's Avatar
Less timing down low=torue
more timing up top=hp
Old Aug 2, 2009 | 09:19 AM
If you are not running methanol injection though you can't really increase your timing all that much over the stage 2 file otherwise you will have knock. If you get methanol injection you can add up to 10 degrees of timing ontop of the 15 in stage 2 for a total of 25 degrees of timing.
Old Aug 2, 2009 | 09:30 AM
o ok. How many counts of knock would i get by rasing timing with no meth
Old Aug 2, 2009 | 09:34 AM
It all depends on how much timing you are running and what afr you are running. But either way, you want 0 degrees of knock at WOT.
Old Aug 2, 2009 | 09:40 AM
well im stage 2 strictly. I have the gm canned tune. So my afr at wot is around 9.6 as i dont have a wideband.
Old Aug 2, 2009 | 09:43 AM
You can run around 18 or 19 degrees with a conservative AFR and not have any problems.
Old Aug 2, 2009 | 09:48 AM
I have seen cars knock with 19 degrees so be careful on that. Basically just increase it a degree at a time and see when and where you get the knock. You should be able to run 17degrees on 93 octane no problem.
Old Aug 2, 2009 | 10:07 AM
daythecountrydied21's Avatar
22-24 degrees depending what i feel like the day i put it on the car without knock without meth injection
Old Aug 2, 2009 | 10:10 AM
I have never seen a car take 24 degrees of timing without knock WITHOUT methanol injection, thats just crazy. Got any logs?
Old Aug 2, 2009 | 12:11 PM
Snakes709's Avatar
im at 24* of timing, no knock....didnt even see any knock during the tuning process. but i have meth, h/e, 2 step colder plugs...lol.
Old Aug 2, 2009 | 12:14 PM
Exactly anyone running meth can see 24-25 degrees of timing no problem, but without meth 99% of cars WILL knock with that much timing.
Old Aug 2, 2009 | 12:19 PM
No my bros stg2 srt4 runs 30 plus degrees timing with no meth nor any knock. That's how much timing the pull stock stg2
Snakes709's Avatar
indeed....without meth...when i had stage 2 on the m62 i got to 17-19* and i seen some knock...so i had to back it down. I highly doubt buddy is making 24* of timing without meth...if he is he probably has 6* of knock.
agreed.
Old Aug 2, 2009 | 12:28 PM
How does meth stop u from having knock
Old Aug 2, 2009 | 12:33 PM
BLAZIN07SS's Avatar
I'm too JDM for you
my 07 gm stage 2 ran 22* of timing w/ no knock, i dont know how or why but it ran great
methanol is super high octane(116 octane rating). remember octane is resistance to detonation
Old Aug 2, 2009 | 12:35 PM
Snakes709's Avatar
meth helps the iat2 stay low, this making it less of a chance of knock. By having no knock and lower iat2 u can put more timing, more timing makes more power.
Old Aug 2, 2009 | 12:37 PM
Actually the distilled water helps cool the iat2's down and the methanol acts as a higher octane which in return helps with detonation. The higher octane you run the more timing you can run. Methanol has an octane rating of like 116, so this really helps when running more timing. This is also why its recommended to run 93octane or higher on gm stage 2/3 vehicles, because they have higher timing maps 15 degrees to be exact. So if you want to run 25 degrees, 10 degrees over stage 2 timing, you really should be running methanol injection.
Old Aug 2, 2009 | 12:40 PM
So could u run a higher octane like e85 and have no meth but still have no knock n pull 10* of timing
Old Aug 2, 2009 | 12:45 PM
You can run higher octane fuel without meth and run higher timing yes. You could run race gas or e85 and run a decent amount of timing yes. However how much timing really just depends on what your motor likes and what octane fuel your using.
